RV.Net Open Roads Forum: Class C Motorhomes: Furnace works; then doesn't; works again?
 > Furnace works; then doesn't; works again?
VA-Apraisr
glen allen, VA
Posted: 11/03/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Yep.....thought about that too, Bob! I also boondock more than hookup, so it's rather important to me. Not sure what a new unit would cost but will ask. Mainly, I want to make sure they pulled it apart versus just put the board in and fired it up once. I think a trained monkey could do that.
bobndot
Posted: 11/03/19 10:16am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Good luck , I hope it's a simple fix for you.
Bordercollie
Garden Grove, CA, USA
Posted: 11/04/19 10:07am Link  |  Quote  |  Print  |  Notify Moderator
I once found a loose screw connection at the fuse panel that caused intermittent furnace action. Look also for loose or corroded ground or +12volt connections at the thermostat and at the furnace itself.
I had an old rig with an old furnace that was intermittent. I had to run the stove to clear air bubbles from propane lines. Furnaces have a lot of safety devices that need to work properly with a steady flow of propane.
* This post was edited 11/04/19 10:15am by Bordercollie *
ron.dittmer
North-East Illinois
Posted: 11/04/19 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Excellent point!
Run your stove for a few minutes to evacuate air in the line, especially after service was just completed on any propane appliance.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
VA-Apraisr
glen allen, VA
Posted: 11/05/19 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Yes, tried the range running to make sure gas was available, turned off tank and back on, turned water heater on, ..... it's back at shop and will post results (positive I hope) once they figure it out. Told them to check digital thermostat and maybe try a manual thermostat; also check regulator to ensure proper propane pressure, and pull heater box apart and look for any rust. Fingers crossed XX
VA-Apraisr
glen allen, VA
Posted: 11/05/19 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
UPDATE: so, they had already replaced the main board (maybe unnecessary?) and nothing had changed. So, this time, the removed the Honeywell digital thermostat and replaced with White-Rogers analog RV thermostat and also straightened out the heating duct beneath the sink/couch/bedroom areas since they said they were "kinked up" in several places and thought that was causing a high heat sensor to trip the furnace off and not auto-start back up. They said they left furnace on last night with temps here going down into the high 30's and said camper was toasty warm this morning. Seems to be working as I type but will know for sure once I'm on the cool beaches of North Carolina this weekend and next week.
bobndot
Posted: 11/05/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the update, it might have been a combination of the thermostat and that kinked hose. Either way, its good news to hear that it cycled enough times to keep it warm.
Enjoy, N.C.
Bob
Old-Biscuit
Verde Valley
Posted: 11/05/19 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like it was the 'thermostat'......
The 'kinked up' ductwork COULD cause issues with air flow (not enough thru the heat exchanger) which would cause overheating and the High Temp Limit Switch would open shutting down gas valve
BUT fan would continue to run....High Temp Limit only stops DC circuit to circuit board NOT DC to Fan.
Fan continues to run cooling down heat exchanger/High Temp Limit Switch Closes ...DC back on circuit board which opens gas vlave/spark electrode fires and re lights because Thermostat Temp Set Point has NOT been reached.
Furnace firing off....reaching t-stat set point and then NOT refiring when temp drops is usually an issue with the thermostat
VA-Apraisr
glen allen, VA
Posted: 11/05/19 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Man o man....you guys are a valuable knowledge pool of thoughts!! Yes, I feel it was mainly the Lowe's brand Honeywell not syncing with the RV. But, I've now got a new circuit board, unkinked ducts and new thermostat. Sadly, throw enough money at it and sooner or later a dart will hit the target [emoticon] I had better be WARM on that BEACH.
ron.dittmer
North-East Illinois
Posted: 11/06/19 06:42am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you are in good order again. I find it strange that your ducts were kinked. Were they kinked since the rig was new? Or are they in places where your stuff has kinked them.
It seems that your digital thermostat might have been the real culprit. We have the mechanical one shown and love it. I would never get a digital one for the way we use our rig.
At home, we had a digital thermostat for many years and we both cursed it. I finally had a Popeye moment "It's all I can stands, and I can't stands no more". We are back to the old round Honeywell with the coil spring and mercury switch inside.
