RV.Net Open Roads Forum: Toy Haulers: Anyone built a new ramp door?
Search only in Toy Haulers
 > Anyone built a new ramp door?
colliehauler
Mc Pherson KS USA
Posted: 11/02/19 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
On my 2009 Keystone Hideout the side 5' wide toy hauler door is rotten at the bottom. I took the door off and the aluminum frame to see it's a sandwich of luan and foam. Need to rebuild and wonder if anyone else has built a new door?
colliehauler
Mc Pherson KS USA
Posted: 11/02/19 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Since it's a smaller door I thought of rebuilding with 3/8 plywood with a foam core. Don't know how much weight it would add.
Y-Guy
Tri-Cities, WA
Posted: 11/02/19 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Search of the archives might help you out ramp door rebuild
fj12ryder
Platte City, MO
Posted: 11/03/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
A lot of the old posts have had the photos removed/made unavailable by PhotoBucket, so it's hard to follow the details.
Post up some details and photos if you would please, I need to check out mine next summer and haven't really decided to jump in yet and just do it.
Howard and Peggy
"Don't Panic"
colliehauler
Mc Pherson KS USA
Posted: 11/03/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Ran into the same trouble with the photos. I need to find the correct balance between strength and lite weight.
fj12ryder
Platte City, MO
Posted: 11/03/19 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, me too. Mine is the full size door at the rear and using lots of lumber will add a whole lot of weight.
colliehauler
Mc Pherson KS USA
Posted: 11/03/19 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
I ordered the filon and can reuse the aluminum perimeter frame. Took off the remaining hardware on the door. Been reading Portscaner's post and it sounds like his door was built different then mine. I will see how much I can apply. Have not scraped off the Luan yet to see how the whole door is constructed, just the rotted part.
* This post was edited 11/03/19 02:18pm by colliehauler *
redhooker
Posted: 11/04/19 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
I helped a friend tackle this recently. Could not use thicker wood on inside as the door would not close without spacing the hinges to accommodate the thicker door. Luan was used. Diamond plate aluminum was considered but he had no time to source a piece cut to fit. Outside skin was intact and reused, but one could also use a sheet of aluminum there as well if you have the ability or availability. Would be lighter and likely better all around. Good luck with the project!
