RV.Net Open Roads Forum: Roads and Routes: Southeast Massachusetts to Nashville TN
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > Southeast Massachusetts to Nashville TN
hedgehog48
Posted: 11/02/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Looking at possibly planning a trip next summer from south eastern Massachusetts to Nashville. Maps look like 95 south to New York, then 287 over tap pan zee bridge . Then 78 into Pennsylvania, 81 to Knoxville tn and then i40 to Nashville. Is this a good route? How is traveling on 81 south versus i95? How bad are the hills? I’m towing a montana fifthwheel with a 6.2 f350 gasser with 4.30 gears. Any input is appreciated.
K Charles
Connecticut
Posted: 11/02/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
I came down 95 a couple weeks ago for the first time in a few years. We usually go 81. I used to come 95 just for something different but I my not do it again, it's not fun any more. 81 is way better
ken56
Tennessee
Posted: 11/03/19 04:54am Link  |  Quote  |  Print  |  Notify Moderator
I think your route is the way to go. 81 at least from Roanoke into K'ville is good with no bad hills. The only grade from K'ville to Nashville is just west of K'ville giong up onto the Cumberland Plateau which is not bad.
lmpres
New Hampshire
Posted: 11/03/19 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Done the north south trip 3 times now. Went 95 (over the George Washington) whole way once, NEVER DO THAT AGAI!. Went over the Tappen Zee the second time. Went all the way out to 81 and skipped the Tappen Zee the third. Skipping the Tappen Zee with the 5th wheel was WAY better!
jplante4
Cape Cod
Posted: 11/03/19 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Our route through there is I-195 to Providence, then I-95 to Old Lyme CT, CT 9 to Middletown then 66/I-691 to I-84. They just finished rebuilding I-84 through Waterbury and Danbury, so if you've been avoiding it, it's better now.
From there you have a couple of choices. You can stay on I-84 all the way to Scranton to pick up I-81 or take US209 down the Delaware Water Gap and pick up I-80 to I-81.
The roads around the NYC metro area are pretty dismal. The new Tappan Zee bridge is great, but the roads to it are still 3 lane and very crowded.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Horsedoc
Dixie --- N. Georgia
Posted: 11/03/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Having been hung up in NYC traffic on some very bad local advice, I might find a way west(I-84 maybe??) above the City and then head south on I-81.
We have traffic in Atlanta, but NYC has TRAFFIC!
DrewE
Vermont
Posted: 11/03/19 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
Your route is reasonable. jplante4's route is also fine. If memory serves, the bit of I-84 through New York state was rather rough the last time I was on it (a year or so ago).
I-81 is in my opinion a much nicer route than I-95 for getting to Tennessee. I-95 through NYC, Baltimore, and Washington, DC is not exactly fun driving. You'd have to go over the Great Smokey Mountains to get from I-95 to Knoxville, presumably on I-40, and that's at least as bad as anything you'd encounter on I-81. There are hills along I-81, to be sure, but they're generally more of the rolling variety than anything. (No interstate is going to have worse than a 6-7% grade in any case.)
hedgehog48
Posted: 11/03/19 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Any recommendations for a 1/2 to 3/4 way stopping point for the night for both the way down and the way back?
TenOC
On the road -- Full time
Posted: 11/03/19 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
When I lived in Belchertown MA we went to Nashville a number (30+) of times. There are 3 acceptable routes. (1) I81 as you suggested or
(2) through PA and Ohio or (3) through upstate NY and Ohio. All are about the same distance and depending on the time of day take about the same amount of time. It depends on what you want to see on the way.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
eastcoasthd
Southeast Ma.
Posted: 11/03/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Just returned from a 4400 mile round trip from SE Ma. to San Antonio Tx.
Departed in the evening at 630 pm. 495 > 90 > 84 > 81 very little traffic made it to Scranton in about 6 hrs. First fuel stop in Danbury Ct. around 170 miles. Exit 8 off 84, Global gas, easy in and out. Second fuel stop just prior to Scranton, exit 8, Liberty Travel Plaza, Mt. Cobb.
A couple of sections E & W bound of 84 in NY west of the Hudson are under construction and reduced to one lane for several miles. Several areas of rough road in both NY. and PA. on 84. Other than that pretty smooth going all the way down to Knoxville.
You should be fine with the hills. Ran into several 3rd gear / 50 mph climbs with my set up. I preferred manually shifting to keep the revs in the sweet spot. Not a big fan of the 5500 rpm, 2nd gear drops while using cruise.
2016 F250 6.2 3.73
2019 Jayco 25.5 REOK (29’ - 9500 lbs.)
