RV.Net Open Roads Forum: Travel Trailers: Blow out water lines question
 > Blow out water lines question
Page of 6
goducks10
There
Posted: 11/09/19 08:38am Link  |  Quote  |  Print  |  Notify Moderator
IMO it really boils down to where you live as to how severe your winters are.
Live in Los Angeles and heck you don't even need to winterize.
Live in North Dakota use the pink stuff.
All points in between it's user discretion.
GrandpaKip
Flat Rock
Posted: 11/10/19 08:11am Link  |  Quote  |  Print  |  Notify Moderator
BarneyS wrote:
GrandpaKip wrote:
I pressurize the lines with AF, then crack the cold inlet on the water heater for a moment to put some in the tank.
Works for me.
Whoa! Glad it works for you but I don't think it will work for anybody else. When you get even a little bit of AF in the hot water tank it is very difficult to get it all out. You will have foamy, smelly hot water for a long time.
If you drain your water heater there is absolutely no need to put anything in the tank. The small amount of water remaining in there will do no harm if it freezes.
Barney
I do it mainly to get some AF in the short line that goes in the bottom of the tank.
I just rinse the tank before heating it. Never had hot water foam. A bit of smell first couple of showers, but nothing to worry about.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
OleManOleCan
Alabama
Posted: 11/23/19 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer wrote:
Lantley wrote:
Fixing the Pex is generally easy enough. It's finding the leak and gaining access to it in order to fix it that is the challenge. That does not include any damage caused by the leak.
Murphy's law dictates the leak will not be in a easy to access spot!
For the record standard insurance policy procedure is to pay for damage caused by a leak but they don't actually pay to fix the leak itself.
The damage is generally a bigger problem than the leak!
My point is use anti freeze and avoid any issues. Antifreeze is cheaper than shark bites. Easier to use than a saw, requires less effort than removing the underbelly. Does involve drying anything out. Antifreeze is also much cheaper than replacing, fixtures, valves,pumps or a host of miscellaneous parts
[emoticon]
Silly person you are, just can't wrap your head around this dirt simple way of clearing the lines.
You simply repressurize the stupid water system WITH AIR in the spring time to TEST the system!
Yeah, it IS THAT simple.
I have to check and fill my tires anyway in the spring, tires lose pressure over the winter months so I do BOTH things at the same time in the spring. Or perhaps you NEVER check and air your tires, perhaps that is why so many folks grumble about tires blowing out on them?
Put 30 PSI of air on the system then let sit for an hr then check the pressure, no drop, no air noise and you are good to go with water.
AIR will not do any damage and you WILL hear it hiss if something is wrong.
A $39 Harbor Freight compressor can easily do both jobs or like I do, add 50ft of air line hose to my shop compressor. I have done it both ways.
EVEN if I were to use RV antifreeze I WOULD STILL PRETEST WITH AIR ONLY in the spring.
That is how you test brand new plumbing in new homes, stub out then add a air gauge then pressurize with air. Wait an hr and check for pressure drop, no pressure drop you are good to go with water.
As far as finding and getting to lines, no, they are not hidden in walls, they are run in a chase at floor level (fivers and some MHs might be under the floor in the basement but still not all that hard to access) in a RV, sometimes may run under the tub but pretty good chance that they WILL be not all that hard to get to..
At least in the several TTs I have had they both have been very easy to get to, out in the open under a couch, base cabinets and such.
Fixtures? Really, $50 at Home Depot or Lowes will get you FAR BETTER faucets than what RV manufacturers use, first thing I do is remove and toss the RV faucets, they are Dollar General quality stuff.
LEAVE the faucets OPEN and absolutely NO water will be trapped in the faucet, PERIOD.
Do YOU fill your water heater up with the pink stuff? Perhaps you should, perhaps you do not realize that when you drain the water heater, the drain IS above the bottom of the tank, it leaves at least 1 inch of water in there (water can't go below the drain hole).
Like I said, IF YOU feel better using the pink stuff then by all means use it. HOWEVER, there have been and are plenty of other folks who do not and never have any issues for many years.
I use a Turkey baster with a piece of rubber tubing to remove most of the water left in the water heater after it's drained.
Mine has about 3/4" of water after I drain the tank.
I get all I can get, and I have never had a problem with freezing and expansion doing damage.
ktmrfs
Portland, Oregon
Posted: 11/24/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I and many of my camper friends have blown out lines for decades and not had any problems. But, our climate doesn't get real cold and for very long, figure 15F for a few days at most, often less, so even below freezing the inside of the trailer and some of the lines don't get below freezing if it warms up during the day.
And we all us pink stuff in the traps.
Just take your time and continue blowing out the lines for 30 seconds or so after it starts blowing air. And blow out the black tank rinser as well.
And the pex lines in todays trailers are more freeze damage resistant than copper. Pex will exand rather than rupture like copper.
However, I know folks in the midwest who blow out lines and don't have problems either.
I prefer blowing out the lines rather than the pink stuff since it makes it MUCH easier and quicker to go camping. No flushing, just fill up and go.
2011 Keystone Outback 295RE
gmw photos
midwest
Posted: 11/25/19 05:43am Link  |  Quote  |  Print  |  Notify Moderator
After I flush all the debris that I can get out of the water heater, I use my wet shop vac with a piece of flexible plastic tubing duct taped to the vac nozzle to remove the remaining water and debris.
drsteve
Michigan
Posted: 11/25/19 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Not necessary. The inch or so of water remaining in the bottom of the WH will not cause any problems.
1991 Palomino Filly PUP
cavie
Posted: 11/25/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
How did simple winterization become so complicated?? Shop vacs, turkey basters, air compressors. 6 gals of air space in a steal tank you you think 3/4" of water it will cause damage? Owners manual says drain the tank. PERIOD. You guys miss Elementary since class? You all need to get a hobby!
drsteve
Michigan
Posted: 11/25/19 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I gotta admit the turkey baster/shop vac thing was a new one...
gmw photos
midwest
Posted: 11/27/19 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Using the shop vac also cleans out much of the debris in the bottom of the tank that is shed from the anode rod.
By the way, I did just fine in science and physics class. Some of us simply like to tinker with our RV's. You'd probably shake your head at the fact I wax my truck once a month too [emoticon] And I wax my trailer with a buffer twice a year.[emoticon]
jrhanbar98
Minnesota
Posted: 11/28/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I’ve blown my lines out every year with no issues. Live in MN so it gets cold and stays cold. Pretty easy empty hot water heater, hook up air and set to 90psi, open up each faucet one at a time, let it go till all you have is mist coming out. I do drop RV antifreeze in the p-traps and toilet. Use way less punk stuff, and easy start up next year, just turn water on. Biggest myth is you need to get ALL water out, it’s okay to have some stay in, just don’t want full blockage of the line by ice.
Page of 6
