RV.Net Open Roads Forum: Fifth-Wheels: first time winterizing my 5th wheel
 > first time winterizing my 5th wheel
shug23
ohio
Posted: 11/03/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I've owned my Mobile Suites 5th wheel for about 4 years and have run away from the winter until this year...SO now I need to winterize for the first time...Been watching the You tube videos and understand most of it....I want to clarify a few things that might be unique to my rig...On the input, I have one switch where the city water is coming in, which I can switch to 'winterize/sanitize...Here I am assuming that I dial it to that setting and this will prevent water/antifreeze from going into the fresh water tank...Is this correct ? Then I have another switch/dial which I can change from normal to 'bypass' which is for the water heater and again, I assume will prevent antifreeze from going into the water heater.....SO after I drain the water heater and open the drain plugs underneath the rig, I plan to dial both switches to the 'correct' position....Then, I plan to pour antifreeze via a funnel into the place which takes in the city water...I 'think' I keep pouring until I hear/see antifreeze coming out underneath the rig, and then I close those valves....I then turn on the water pump and go inside and run each faucet, shower, toilet until I see pink RV fluid coming out...…...Does this all seem correct ? I am not planning to blow the lines out with air as I do not carry a compressor. Thank you for any corrections or advise......As far as my batteries go, I have four 'golf' cart batteries...I am planning on taking all four inside a warm house and putting each of them on a trickle charge......I'll put tire covers on...I'm storing the rig on concrete, so Im not thinking I need to do anything special with the tires other than making sure pressure is good
djousma
SW Michigan
Posted: 11/03/19 08:31am Link  |  Quote  |  Print  |  Notify Moderator
I hope someone with a MS gets on here to give you some good info. If you have never winterized, you might consider bringing it in to be done. Reason being, if not done right, and water freezes in the lines, you will be looking at potentially thousands of dollars of damage come spring.
That said, You most likely will have to use the onboard water pump to siphon the AF in through all the lines, and out all the fixtures. you don't want to pour AF into the fresh water tank if you can help it. If you have a dishwasher, or clothes washer, builtin ice maker, those all take additional steps to properly winterize.
Good luck, and hopefully someone with rig similar to yours will come along and give better information.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
Super_Dave
Harrisville, UT
Posted: 11/03/19 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Get a piece of vinyl hose and a male garden hose fitting. With the end of the hose in the bottle of RV anti freeze, turn on the water pump and open a faucet. When pink starts to come out, shut it and move on to the next fixture. Remember to do outside shower and wash machine hose bibb if you have one. Have someone outside to help you switch bottles, mine usually takes 2 gallons. Pour the little bit left in the bottles into the drain traps in sinks and shower.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
RobWNY
Jamestown, NY
Posted: 11/03/19 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a Black Tank Flush connection, get some anti-freeze in there too. There's a Anti-Siphon Vacuum Breaker/check valve, usually plastic and situated under the bathroom vanity that will likely still have some water in it as well as the Pex pipe that it's attached to. They sell hand pumps to winterize this part but I just take a piece of garden hose and screw it on to the flush connector and then use a funnel to pour anti-freeze through the hose and into that area. Lift the hose above the connector until it flows in and that should be good. Also, don't forget about the washer/Dryer plumbing if your rig is equipped for them.
If God didn't want us to eat cows, he wouldn't have made them out of Steak and Cheese.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
shug23
ohio
Posted: 11/03/19 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Sugar Dave....where is the other end of the vinyl hose attached to ? the city water input ?
To anyone…..how do I winterize a dishwasher ?
DutchmenSport
Indiana
Posted: 11/03/19 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Here's what I think is going on and how to handle it.
Drain your water heater.
Flip the valve Normal / Bypass to Bypass. This will bypass the water heater.
It sounds like you have a gravity fill port for filling the fresh water tank. Do not put the antifreeze in the fresh water tank. You will have a very, very hard time flushing it out when you are ready to use it again.
It sounds like you have a hose connection to attach a garden hose to the water system. When the garden hose is turned on, your water pump is turned off. And the water runs through your camper via the pressure from the water source.
If you flip the valve to Winterize/sanatize, you will need to attach a different hose. The hose should have the normal garden hose threaded attachment, but the other end should be cut so it can be stuck into the gallon size RV anti freeze.
You now turn on the water pump and it will begin to run, sucking the antifreeze up until the system pressurizes. The pump will shut off. You now go around to each faucet one at a time, hot and then cold and turn them on until clear water turns all pink. Then go to the next faucet.
If the pink stuff is pouring out low point drains, then the low point drain valves are open. Close them, or nothing will ever make it to the rest of the water system.
If pink stuff begins pouring out the bottom of your fresh water tank, then the in-line check valve between the fresh water tank and the pump is failing allowing pink stuff to feed backwards into the fresh water tank.
If you have access to the water pump itself, you might check to see if there is a separate valve there too. One direction would be for the fresh water tank, to suck water up, the other direction would be for the other "in" line that would suck water from the garden hose connection. (my best guess is, there is another valve there that needs to be flipped.)
The bottom line is, I really don't know how your system is designed, I'm only guessing how it might work if you have only 2 valves to flip.
My previous camper had a by-pass valve right at the water heater, and I added the valve to flip right at the water pump to switch from pumping from the fresh water tank or the hose that gets stuck in the antifreeze jug.
My current 5er has a valve for bypass (water heater), and inlet for winterizing (the pump sucks it up there), and another switch to fill the fresh water tank or run "normal" via the garden hose. If running "normal" via the garden hose, the water pump needed to be turned off.
So... bypass, connect hose and insert into antifreeze jug, turn on water pump. Turn on each faucet, one at a time. Try that, see what happens.
cavie
Posted: 11/03/19 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Youtube is your friend MANY video for you to watch.
laknox
Arizona
Posted: 11/03/19 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
If your rig is like most others, you should be able to simply suck the anti-freeze directly from the bottle using the pump and a short hose. (You can do the same thing, with the correct valve setting, to suck water into your fresh tank from a spare jug or bladder when boondocking.)
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Super_Dave
Harrisville, UT
Posted: 11/03/19 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
One end of hose in bottle and other end to city or water intake fitting.
garyp4951
TN
Posted: 11/04/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
On a dishwasher I would think you need to pull the bottom front panel, and remove the drain, and discharge connections. i don't know if I would run antifreeze through it to avoid this.
Maybe someone with an RV DW will respond.
