RV.Net Open Roads Forum: Fifth-Wheels: first time winterizing my 5th wheel
 > first time winterizing my 5th wheel
djousma
SW Michigan
Posted: 11/04/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
No problem running af into the dishwasher. It's not just the water inlet, it's also the drain pump as well. Start a cycle, let run for 20 secs, cancel which starts drain. All done.
Same process with washer, just do both hot and cold sides.
* This post was edited 11/05/19 12:17pm by djousma *
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
garyp4951
TN
Posted: 11/05/19 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Thats good info, might need an extra gallon of AF.
shug23
ohio
Posted: 11/06/19 07:12am Link  |  Quote  |  Print  |  Notify Moderator
thanks everybody; I think I am in good shape to do this myself...But here is an additional (dumb?) question...The reason I am winterizing is because I bought a home in Oklahoma...I just found out my new home has a 50 Amp hook up already set up for an RV....Now I am wondering if I can somehow take advantage of this hook-up...i.e put a space heater in the RV and one in the basement of the RV after draining, ( I once had a TV screen crack in below freezing temperatures)....I stil want to remove the batteries to put them on trickle chargers inside my new home...does anyone know if , by removing the batteries, I will be able to use the RV outlets to plug in a heater....
Veebyes
Posted: 11/06/19 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I am about to winterise mine. Waiting for DW to finish need for water. We are on own tank. Drain hw by low point or anode removal. Switch to bypass so heater does not refill. Either use a 2 way valve on tank side of pump or disconnect & use a hose with connection to tank side of pump. Do the pink stuff suction thing each outlet hot & cold till pink flows. When all done turn the pump off at switch. Drain water tank at low point. This could take awhile if tank is fullish. Off you go to a dump & drain tanks completely. If like us the trailer will feel amazingly light on the way to storage with no liquids onboard.
2007 Alpenlite 34RLR
laknox
Arizona
Posted: 11/06/19 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Seems to me that an oil-filled heater inside and leaving the furnace fan on would take care of both. Either way, leave all the lower cabinet doors open to keep the cold from "pooling" there. I've read more than one story where someone's had their rig at 50, yet still froze under-sink pipes from the cold coming through the walls.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Dave H M
IL
Posted: 11/11/19 06:57am Link  |  Quote  |  Print  |  Notify Moderator
I conjured up a chunk of hose to go from the outside shower outlet to the black tank flush.
