RV.Net Open Roads Forum: Fifth-Wheels: Carriage Cameo 2006 Window
 > Carriage Cameo 2006 Window
boatscr
Emery, SD
Posted: 11/03/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
The repair shop says I need a new window but doesn't know the brand. Neither do I. Any help out there to find a new window?
Darryl&Rita
Grande Prairie, Alberta
Posted: 11/03/19 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Damaged frame? Broken glass? Either way, find a glass shop instead of an RV repair shop. Brand is probably a Herh.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
banjo
Central Texas
Posted: 11/03/19 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are Hehr. Don't know if Carriage used Hehr in 2006.
Banjo
2011 3500 DRW D/A CC LB 4X4
2011 Cameo 34SB3
http://www.pearlbluegrass.com/
Petethescot
White Rock
Posted: 04/20/20 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Can a glass shop replace the glass only in a frameless window?
Veebyes
Posted: 04/21/20 06:08am Link  |  Quote  |  Print  |  Notify Moderator
We rode around for a couple of years with a cracked bedroom window.
Hunted all over for replacement window. No luck. Finally tried a small town mobile glass guy. He came to the CG, set up shop right there, 2 people, & in an hour for $200.00 the job was done.
The material used was lexan, not tempered glass. Extremely tough stuff.
2007 Alpenlite 34RLR
ereed52
Columbus, OH
Posted: 04/21/20 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Hehr part number location
Inside frame and/or window will need to be removed to fine part number.
Or remove inside frame measure hole and order new window.
