RV.Net Open Roads Forum: Tech Issues: Replacing 12-volt batteries with 6-volt
 > Replacing 12-volt batteries with 6-volt
ksg5000
Oregon
Posted: 11/04/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Also - make sure you have room for the sixers - they are taller than the 12's and in my rig they won't fit.
Kevin
bob213
Fresno, CA
Posted: 11/04/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Check here forhow to wire them.
12 volt side of life
ktmrfs
Portland, Oregon
Posted: 11/04/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
6V advantage
1) can take 500+ charge discharge cycles to under 50% (more like 25%) SOC
Disadvantage:
do NOT work well with high current loads, like even 1000W inverter. First ALL the current is coming from each battery vs 1/2 the current from each battery in a similar parallel 12V, Next, they have much higher internal resistance than a 12V which means more voltage drop
6V vs 12V IMHO really depends on YOUR application. If you only occasionally dry camp, or often use high inverter loads, then 12V may be a better alternative.
If you often dry camp, can keep your load down to 50A or less peak, 6V may be a better choice.
2011 Keystone Outback 295RE
time2roll
Posted: 11/04/19 10:25am Link  |  Quote  |  Print  |  Notify Moderator
I went with 4x GC2. Wire is easy.
Click on my solar set up for a battery picture.
675w Solar pictures back up
3 tons
NV.
Posted: 11/04/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
ktmrfs wrote:
6V advantage
Disadvantage:
Note that I have for a out 6 years routinely run my Coleman Mach 1 P.S. 11kbtu air conditioner for brief periods (up to an hour or more concurrent with 440w solar) from two 6v GC’s without a hitch (via ProSine 2.0 - 04 aught cables), with locked rotor starting amps at about 140amps - now running Costco GC’s...Cables do MATTER...
TomG2
Central Illinois
Posted: 11/04/19 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
marcsbigfoot20b27 wrote:
Swapped the whole thing to 3 AGM 12 volt deep cycle batteries in parallel and couldn’t be happier. My solar charges them faster also.
That is a not often mentioned advantage of sticking with 12 volt batteries. One, two, three, four, or five all increase available power without having to buy in pairs.
2oldman
New Mexico
Posted: 11/04/19 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yup kinda and I hated it. Had one 12 volt from the factory. Added two 6 volt GC2 batteries to power my inverter. .
Maybe you should have removed the 12v.
2 -6v batteries are not enough for any big draw inverters. 4 minimum, 6 is better, but incredibly heavy.
bpounds
Sophmore Brain...
Posted: 11/04/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
hedgehopper wrote:
Have you replaced two 12-volt batteries in parallel with two 6-volt batteries in series to improve ampere hours? Were the results satisfactory? Please elaborate. Was the rewiring difficult?
Just do it. You'll be happy you did.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Wherever I happen to park
Posted: 11/04/19 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
SO that you know. with large inverters Xantrex suggests at leat one pair GC-2 per kilowatt of inverter.. Now when my GC-2s were new one pair would cook my lunch in the 1100 watt microwave with the 2KW inverter but they suggest one pair per KW.
And when you do the "how much power" math. for inverters assume 10 volts from the battery.. not dead on but by the time you factor in conversion loss (About 10 percent) and line loss.. Darn close.
Home is where I park it.
philh
Belleville MI
Posted: 11/04/19 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
You must change out the convertor charger and get rid of the POS WFCO. I love my 2 6v batteries. Haven't run anything heavy, but they have performed well for me.
