RV.Net Open Roads Forum: General RVing Issues: Storage in Barn for winter.
 > Storage in Barn for winter.
Fire19
Michigan
Posted: 11/04/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
I have just completed my new pole barn and will be storing the fifth wheel in there once the concrete cures enough. My question is since I now have electricity in the storage barn should I leave it plugged in or should I remove the battery? Should I put Wood under the tires for the storage time?
2000 Ford F-350 Dually Crew Cab
2002 Gulfstream Seahawk 29FKS
1998 GL1500SE
BarneyS
S.E. Lower Michigan
Posted: 11/04/19 09:16am Link  |  Quote  |  Print  |  Notify Moderator
If your trailer has a "smart charger" in it like the
Progressive line with the "Charge Wizard" then I would leave it plugged in. Our trailer used to sit plugged in 24/7 for about 12 years with no damage and the batteries lasted around 7 or 8. All I had to do was check the water level a couple of times/year - usually without having to add any.
There are other brands that have just about the same technology also.
You could use a stand alone smart battery charger like a "Battery Tender" brand that would work fine also if your converter is not a newer model.
No need to put wood under the tires. Just inflate to normal (usually max sidewall pressure) and they should be good for the winter. If the trailer was going to sit on the dirt then I would put something under the tires.
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
opnspaces
San Diego Ca
Posted: 11/04/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately your question requires a "that depends" answer as it depends on the battery charging system. I see in your signature that you have a 2002 Gulfstream Seahawk 29FKS. Being that old it's highly possible that the converter/charger system is only a one stage. If that is the case then you can not leave it plugged in without boiling the batteries dry. If you can look at the converter/charger for a sticker or label and tell us the make and model we can help figure out if it's a 3 stage charger.
As far as the tires it makes no difference if you store it on dirt, gravel, wood, asphalt or concrete. But you might want to put the landing gear legs on some wood to prevent gouging or rust stains in the concrete.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Fire19
Michigan
Posted: 11/04/19 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I should have stated I just replace the converter in 2016 with the following Progressive Dynamics Inteli-Power PD9245C 45 amp Series Converter/Charger.
BarneyS
S.E. Lower Michigan
Posted: 11/04/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Then just leave the battery in the trailer and plugged in. The battery will stay maintained as it should be and ready for use next spring. [emoticon]
Barney
Fire19
Michigan
Posted: 11/04/19 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the information.
K_and_I
North Central Ohio
Posted: 11/04/19 10:19am Link  |  Quote  |  Print  |  Notify Moderator
On concrete that fresh, I would put some wood under it, at least for this year.
K_and_I
2011 Rockwood 2604
Nights Camped in 2019: 85
Do we have time for shortcuts?
DutchmenSport
Indiana
Posted: 11/04/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
If on dirt or grass, yes put lumber under the tires for the sole purpose of keeping the tires from sinking. On Asphalt and concrete, nothing is needed, unless you just want to spread the weight of the camper over a larger foot print. Gravel is 50/50. It depends upon how solid the gravel bed is. If it's not very deep, and tires are subject to sinking with mud under the gravel, the lumber under the tires is probably a good thing. If it's packed solid and deep, lumber is not really needed. Previous house, previous TT, parked on gravel, always on treated lumber. Current house, one side on lumber, the other not. (the driveway has a 4 inch slope side to side for deliberate drainage one direction). So 5er needs lumber under one side to make it more level.
Plugged in? Ours? 24x7x365. It depends on your converter.
Something to think about? If the pole barn is an open barn, consider keeping the camper in ready mode, so if you want to spend week-end in it, you can. Power up the heat and enjoy watching television and sleeping in it. Don't need water. Take a gallon jug of water so if you need some, put a port-a-potty in the bathroom and dump in the house toilet every day, rinse and use it again, snuggle in bed with .... well... your choice [emoticon] take some microwave pop corn and enjoy some time in it. Under a roof, the camper should do very, very nice in cold weather. Enjoy. Do dishes in the house, take trash out at the end of your weekend, and enjoy the camper throughout the winter this way.
MFL
Midwest
Posted: 11/04/19 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Agree with Barney...both posts.
Jerry
gbopp
The Keystone State
Posted: 11/04/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Barney
Don't forget to occasionally check the electrolyte levels in the batteries.
