RV.Net Open Roads Forum: Class A Motorhomes: 100K miles
 > 100K miles
js218
on the road
Posted: 11/04/19 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Meant to say I have 165,000 miles on my rig
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
wolfe10
Posted: 11/04/19 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
oldave wrote:
100k just shows it was put together right , didn't blow up during
break in .
You probably know about the recall on the rear trailing arms for your
chassis .
Chances are the arms have already been replaced , so an alert just in
case .
The original Monaco is long gone so you will have to pay for it
yourself .
Source Engineering makes replacements .
Details of the trailing arm issue:
https://community.fmca.com/topic/570-ser........afari-chassis/?tab=comments#comment-2686
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
oldave
Tx
Posted: 11/04/19 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Lurker52 wrote:
2001 did not use the same trailing arms Per Source Engineering. The bad one started in 2002
Thanks
Good news , Thanks
Obviously I didn't know that , actually I thought all the Knights
of that era were the same .
I would still scoot under with a strong flashlight and look them
over myself , make sure there was no cracks .
I believe at one time there was pictures on the IRV2 Monaco forum
wolfe10
Posted: 11/04/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Pictures in second post in this thread:
https://community.fmca.com/topic/569-imp........t-safety-issue-monaco-hr-safari-chassis/
Lurker52
at large
Posted: 11/04/19 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
I've been under it more times than I would care to say. I replaced the rear air bags a while back. The front ones will be done soon. Everything looks good.
Charley67
Fulton, MS
Posted: 11/04/19 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve owned 3 trucks with the 5.9. That coach will fall off of it before that engine gives up the ghost.
1320Fastback
Vista, Ca
Posted: 11/04/19 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
The 5.9 is based on the 12 Valve which has been around since 1983 I believe. It was designed to operate at 100% duty cycle all-day long in tractors and pumps. In trucks and highway vehicles you should get no less than 500,000 miles before major overhaul assuming all regular maintenance is done and the cooling system is maintained.
Your concern more should be aimed at the transmission and all the systems and seals of the motorhome. The engine, while underpowered for your application is good.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
Ava
Vancouver Island. BC Canada
Posted: 11/04/19 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Most mechanics and long time rv folks say my old 12 valve 5.9 Cummins with the Allison trans will out live the motorhome. 25 years so far.
sjholt
Henderson, NV
Posted: 11/05/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
25 years here too. 198,500 miles on my 5.9 12 valve and still runs great.
I have a bypass oil filter and run the oil 15-16,000 every change and Blackstone says wear is low and I'm good to go 3,000 miles more each oil change.
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
 > 100K miles
