RV.Net Open Roads Forum: Travel Trailers: Dexter 7K axle seals
 > Dexter 7K axle seals
djglover7
Posted: 11/04/19 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Dexter axle newbie here,
I have just secured a horse trailer w/LQ that will be used as a motorcycle hauler RV (a Bloomer).
It has tandem Dexter 7K torsion axles that need a good dose of TLC/R&R.
Are there USA made components? I *really* do not want to work with Chinese components.
Thanks in advance,
Dennis
drsteve
Michigan
Posted: 11/04/19 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Timken.
1991 Palomino Filly PUP
djglover7
Posted: 11/04/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
When I get all the part #s from the axle, is there a good single source for Timken?
Lynnmor
Red Lion
Posted: 11/04/19 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I bought Timken bearings from Summit Racing
Other axle parts are available from eTrailer. Do not buy their Chinese bearings.
lenr
Indianapolis, IN
Posted: 11/04/19 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
I believe that Timpken has both Chinese and American manufactured bearings. You know which ones you want. Axle bearings were standardized years ago with all manufacturers using the same sizes, so you can get them from your local store if you choose.
Huntindog
Phoenix AZ
Posted: 11/04/19 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have a friend that bought the same. He ended up replacing his axles. The rubber "springs" had degraded to the point that they had to be replaced. His shop tried repositioning (clocking I think it was called) to get them back, but they would not hold the new position.
I suggest having them checked over by a good shop, before throwing money in parts at them.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
richardcoxid
Idaho Falls, ID
Posted: 11/05/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Use American made seals! Also purchase double lip seals with a garter spring! The store should have a cross reference book for the seal #s. Clean the area on your spindles where the seal rotates. Lubricate the seal lips when installing. These are MUCH better seals!
2017 GMC Denali 3500 4x4 Duramax
2019 Outdoor RV (ORV) Timber Ridge 24RKS
djglover7
Posted: 11/05/19 09:35am Link  |  Quote  |  Print  |  Notify Moderator
I understand about the double-lip seals.
BUT, I cannot find anyone who advertises "made in USA".
Lynnmor
Red Lion
Posted: 11/05/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
While I have had cheap Chinese bearing problems, I didn't have any problems with using whatever I could find in seals. If you don't use the zerk fitting, I doubt that you will have a problem.
deltabravo
Spokane, WA
Posted: 11/06/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Etrailer doesn't sell Timken parts when I was trying to buy earlier this year.
Your best bet is to source Timken bearings from a local bearing supplier.
Brown Bearing and McGuire Bearing are two that I use in the PNW
2018 Timberridge 24RLS (bought pre-owned 3/12/20)
