RV.Net Open Roads Forum: Which direction do you spin the trailer brake adjuster?
 > Which direction do you spin the trailer brake adjuster?
wopachop
lb
Posted: 11/04/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Going to try and talk my friend into letting me adjust the trailer brakes. Ideally i would inspect and grease the bearings but there is noway thats gonna happen before they go on a trip. I was the last one to tow the trailer and the brakes seemed weak. Full manual control wasnt doing much. I have a clamp meter and have read i want to see about 3a to each wheel. Which i will check later. Im pretty sure due to age the brakes need adjustment regardless.
If im allowed, im just gonna jack each tire up and spin the adjustment until i hear scrapes, then back it off. Is that correct?
Im worried the first wheel i do i might spin the wrong direction. Causing the brakes to be so loose that a component falls off. (no idea if thats possible or not) I would just pull the drum off but thats potential for the whole "why you messing with my stuff".
Been watching videos but havnt come across one that shows the direction that tightens up the slack.
If doing the driver side tires do i spin the little sucker upwards or downwards? Is the passenger side opposite?
Thanks for any advice. I know we should grease bearings but this conversation comes up with all types of things. She thinks "if it aint broke dont touch it". While ive always been a fan of regular preventative maintenance.
Lynnmor
Red Lion
Posted: 11/04/19 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Don't make it so difficult, just turn till it drags and If that doesn't work, turn it the other way. With a flashlight you can see the threads if want to see which direction will make the adjuster expand.
See Page 13 for the procedure. No, listening for noise is not the correct way to adjust.
wopachop
lb
Posted: 11/04/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks so much!
time2roll
Posted: 11/04/19 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Just remember "Down and Out" When you move the lever down the shoes move out.
The different sides have reverse threads so it works same on each.
675w Solar pictures back up
wnjj
Cornelius, Oregon
Posted: 11/04/19 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a decent YouTube video (not mine): https://www.youtube.com/watch?v=waNWLWy7sDY
wopachop
lb
Posted: 11/04/19 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Sweetness!! Down and out will remember that always.
Thanks for the video will give it a look.
whiteeye42
Rock Springs Wyoming
Posted: 11/04/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Turning the wheel so that the teeth on the wheel move upward will expand the brake shoes against the inside of the brake drums. Moving the teeth downward will contract the brake shoes. these instruction came from ETrailer.com Also raise each tire off the ground so you can spin it while adjusting take it until it stops and then back it off until it just spins with slight drag
Me,Wife two boys and two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
wopachop
lb
Posted: 11/04/19 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Rock on yeah just watched the video. Upward on the teeth expanded for that particular brake model. I didnt realize you could see the threads so easily.
Now the real hard part is asking to do it!! I might just wake up early and do it while everyone is sleeping.
ScottG
Bothell Wa.
Posted: 11/04/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a newer rig and are adjusting it the first time, make sure both adjusters on the same side turn the same way.
My trailer had the wrong adjuster on one wheel. It's an auto adj system so everytime I hit the brakes, it loosened them!
That happened right up until it totally came apart inside the drum and made all kinds of noise I could here as I parked. Adjuster was destroyed.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
bpounds
Sophmore Brain...
Posted: 11/04/19 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
This was kind of touched on above, but so it doesn't get missed I'll repeat it. I like to tighten the shoes hard into the drum first. Then back off until I can spin the wheel with slight drag. What that does is force the shoes into concentricity with the drum. If you don't do that, and only snug up until you feel/hear drag, chances are only 1 shoe is doing the dragging.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
