RV.Net Open Roads Forum: 2007 workhorse w22 rear wheel axle seals
 > 2007 workhorse w22 rear wheel axle seals
visavis47
Georgia
Posted: 11/04/19 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
I currently have a leak in the passenger side rear wheel inner seal. All I can find is workhorse part number (way too expensive). Does anyone have the manufactures part number?? Would like to have both outside and inside seal part numbers...Thanks
rgatijnet1
Posted: 11/04/19 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
It is a truck rear axle and WH used a few different brands. I believe yours may be a Dana rear axle and parts are readily available from truck service shops.
allbrandauto
maryland
Posted: 11/04/19 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
the seal will have a part number on it google that number
FIRE UP
Lake Havasu City AZ
Posted: 11/04/19 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Unless things have changed dramatically, there will be NO outside axle seal. All that seals the diff fluid from escaping is the end of the hub, is the axle end, with all the bolts tight. About 98% of the diff builders for the larger truck axles, use no actual gasket. They may use Silicone.
As for the inner one, why don't you just simply remove the hub and wipe things off and see for yourself, what the number is? It will be right there, on the outside of the seal. It could be a "CR" or, Chicago Rawhide brand. But, this way you'll know EXACTLY what the seal part number is and you can cross reference it to your hearts content.
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
GREGORYJ
Lac Du Bonnet, Manitoba
Posted: 11/04/19 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Your rear end is likely labeled as a Spicer model # S-130.
The Workhorse seal # is W8000276 and the Dana-Spicer's part # is W20HH100.
https://www.finditparts.com/products/2030547/dana-holding-corporation-
w20hh100
Or made by SKF part# SKF 35000
https://www.rockauto.com/fr/moreinfo.php?pk=1837330&jsn=8
Also see DIY video of replacing seal:
https://www.youtube.com/watch?v=ZNw5wYmektE
* This post was last edited 11/06/19 07:49am by GREGORYJ *   View edit history
Ellen & Greg
08 National Dolphin DL-35Ci, Kelderman Air Ride, Rear Trac Bar
Workhorse W22, RoadMaster Rear Sway Bar, Towing 08 Smart Car
JRscooby
Indepmo
Posted: 11/05/19 04:21am Link  |  Quote  |  Print  |  Notify Moderator
Scott
And while you are there you can read the bearing numbers. Most times, if the seal lasts a week, then starts to leak it is a safe bet you have bearing issue. (If it doesn't last a week? Installer issue)
visavis47
Georgia
Posted: 11/07/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. Needed the part number because I am not doing the install and don't have a seal in my hand. Gregory J thanks much.
