RV.Net Open Roads Forum: Fifth-Wheels: dissecting a Lippert Ground Control 3.0 landing leg
 > dissecting a Lippert Ground Control 3.0 landing leg
obie311
Aux Arcs
Posted: 11/04/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have the electric Lippert GC 3.0 front landing leg that failed on me in Arizona this spring. I have boxed up the motor for a spare as I believe it is OK. I will test it later.
I'd like to do an autopsy on the leg to see what failed and also to see if there's any salvageable parts inside. The only possible disassembly point I see is on the top. There's a cotter key retaining a pin that can be driven out on the motor coupling socket. After that I haven't a clue. I've looked for an exploded drawing of the leg to visualize what's inside but no luck with that.
Has any of the esteemed members here taken one apart?
Hoppy220
Ohio
Posted: 11/05/19 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
There is a nut in the top of the leg that usually strips out due to lack of lubrication. Once you remove the cotter pin you can remove the inner sleeve and unthread the acme screw from said nut. They are really simple to disassemble once you remove them from the unit. They should have installed a grease fitting on these because the grease gets wiped off the threaded rod with use and then its left to run dry.
harley hitchiker
south west pa.u.s.a.
Posted: 11/05/19 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
there are some pictures posted on jayco owners forum under 5th wheels and heading 3.0 ready to fail . saw it today
Edd505
Elephant Butte, NM
Posted: 11/05/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
This might help GC 3.0 manual:
https://support.lci1.com/ground-control-3.0-support-ground-control-3.0-onecontrol-touch-panel
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
ependydad
Here and there
Posted: 11/06/19 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Is this something I'm supposed to be lubricating? If so, how?
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Hoppy220
Ohio
Posted: 11/07/19 06:27am Link  |  Quote  |  Print  |  Notify Moderator
There is no way to get to it to lube it without complete disassembly. I run landing gear all the way out and spray gear lube through an opening in the outer housing hoping to get enough on the rod to help it out. It's just a bad design on liperts part.
laknox
Arizona
Posted: 11/07/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, it's not only LCI that has this issue. Most landing legs don't seem to have any way to lube them. Personally, if I were to do so, I'd use a "dry" lube, one that won't attract, or keep, dirt.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Bob Shaw
Newnan Ga
Posted: 11/07/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I e got a schematic for the leg, but I won't be able to get to it for a couple of weeks. Just be aware, Lippert does not sell parts for the Ground Control 3.0 legs. I bent my drop legs and had to have the Venture style drop legs machined to get them to fit.
