RV.Net Open Roads Forum: Class A Motorhomes: what is it
 > what is it
sssooo
Ohio
Posted: 11/04/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2018 Fleetwood Bounder 36H that has a rocker switch behind the sliding door above the passenger seat don't have any idea what it does?[image]
[image]Click For Full-Size Image.
I also have a HDMI cable that is behind the DVD player that I cant get it to do anything? I hooked it to the dvd player it didn't show up anywhere?[image]
Bob & Ann
North AL
Posted: 11/04/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
It could be the amplifier for your over the air TV.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2014 Jeep Wrangler Unlimited Toad
Demco Dominator & Airforce One
dodge guy
Bartlett IL
Posted: 11/04/19 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
I'm guessing it's for the satellite. If you turn the switch on you should hear the satellite move.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Wherever I happen to park
Posted: 11/05/19 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Well two good guesses up there
1: OTA antenna amplifier.. If you do not have either a matrix switch (Box of many buttons) with a POWER button. or a wall plate with teh 12 volt outlet, antenna connection, switch and light. or a Sensar Pro. that's a good chance.
2: Satellite antenna (rooftop dome) you will have a Dome up there.
The lack of "Winegard" on the switch suggests a dome.
Home is where I park it.
sssooo
Ohio
Posted: 11/05/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Ok the lite does not turn on when pushed?the switch does not stay pushed in when pushed it springs back to the same position it just rocks back to original position
It’s not tv booster
nomoreosama
South FLORIDA
Posted: 11/07/19 10:03am Link  |  Quote  |  Print  |  Notify Moderator
That switch is used for the ceiling lights, when the bed above the captains chairs is in the down position. So the person sleeping up there does not have to get down to shut off the lights.
[emoticon]
 > what is it
