RV.Net Open Roads Forum: Fifth-Wheels: Trailer leaning
 > Trailer leaning
gmg
Houston, TX, USA
Posted: 11/04/19 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Noticed today that the trailer was leaning some to the right toward the right side of the road. There is also about an inch more clearance between the bottom of the nose section and the truck bed rail on left side. The rig tows straight and has no pull to either side. It just leans to the right some. I looked under it for a broken spring or shackle but all appears fine. Has anyone heard of adding a spacer to raise it up some? What could be the likely cause of this? Has anyone else experienced this situation and what did you do to resolve it and what did it cost?
2013 Ford F-250 Powerstroke Crewcab; Pullrite Superglide Hitch; 05 Everest 294L 5th Wheel.
fj12ryder
Platte City, MO
Posted: 11/04/19 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Is the front leaning the same amount as the rear? Does it actually lean when measured, or does it just look like it's leaning?
Could be flattening springs, worn shackles/bolts, frame fracture, hitch mount fracture, very hard to say.
Howard and Peggy
"Don't Panic"
laknox
Arizona
Posted: 11/04/19 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
I'd say weakened spring or even a broken spring that you can't see. Could also be wear in the hangers, bolts and spring eyes. I'd first weigh the FW side to side, to be sure that it's simply not uneven weight.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
wing_zealot
East of the Mississippi
Posted: 11/05/19 05:09am Link  |  Quote  |  Print  |  Notify Moderator
Maybe it's heavier on that side. Not unusual to have one side heavier than the other, which would make it "lean".
TxGearhead
Posted: 11/05/19 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Used to be a spring shop near downtown named Heitman Spring. Not sure if it's still in business. Might check with them.
Also Axle & Wheel aligning on HWY 225 at Richey might help.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
DutchmenSport
Indiana
Posted: 11/05/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Most roads are made with a slope to the outside edge. Are you sure the "lean" is not just an allusion because the road itself has a lean? Find somewhere where you know the surface is flat, like a very large parking lot. Drive there and see what the rig looks like.
I had a horrible time with my truck dealership repair shop when the truck was new. I kept complaining how the truck seemed to always pull to the right. LONG story short, after a couple front end alignments, changed tires, and replacing springs, it still pulled to the right. Then one day I was driving on a truly "flat" road and noticed it had no pull. That's when I realized, and really started taking note of how many roads are built with slopes to the edge for water drainage. When towing my 5er, I can really see the "lean" because the 5er is so tall.
It's just something to consider before tearing things apart that don't need to be torn apart.
MFL
Midwest
Posted: 11/05/19 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Very true Dutchmen, but OP states that the trailer is leaning and not the truck. He says the trailer is one inch closer to bed rail on one side.
I have towed down some old, little used, but paved, county roads, that were so sloped, that with no traffic, I would tow down the middle.
Jerry
laknox
Arizona
Posted: 11/05/19 09:15am Link  |  Quote  |  Print  |  Notify Moderator
A =good= alignment shop will put just a hair of "left turn" in the front end to help a vehicle track straight. Offsets the crown that 90=% of roads have.
Lyle
gmg
Houston, TX, USA
Posted: 11/05/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have discovered the problem. I would post a picture but do not know how to do that. There is a center rocker piece between the two axles. That rocker then is attached to the leaf spring by two straps (inboard and outboard sides of the spring) the straps have pulled apart where they attach to the bolt.
laknox
Arizona
Posted: 11/05/19 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
That's called an equalizer. Self-explanatory if you think about the mechanics of it. If that's failed, then that could do it. If the one's gone bad, the other one likely isn't far behind. Since you need to replace the equalizers, think about replacing them wit one that's cushioned. Several are available. On top of that, a wet bolt kit wouldn't be amiss. This replaces the cheap plastic/nylon bushings with bronze ones, heavier spring shackles and greaseable spring bolts.
Lyle
* This post was edited 11/06/19 08:20am by laknox *
 > Trailer leaning
