RV.Net Open Roads Forum: Tech Issues: Tow Vehicle Battery and Alternator
 > Tow Vehicle Battery and Alternator
Page of 5
grizzzman
salt lake city, Utah
Posted: 11/07/19 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to purchase and install the 40 amp DC to DC charger. Couple questions though.
A signal control (ignition line) is required to activate this device. Considering the application is a tow behind trailer, can I use the 7 pin trailer harness to tap into for a 12 volt source instead of running a separate line all the way back to the TV's ignition circuit? It would either be the #4 pin (aux) or #3 pin (tail/running lights). I think the tail lights would be a better option as I could control the unit's power via the headlight switch. Thoughts?
Most newer trucks switch off power to the plug with key off. With that said you would need to disconnect or install a diode to keep the trailer from back feeding and causing the charger to stay on. Any 12 volt circuit that would turn off when you want it to will work.
Also, the Renogy wiring diagram shows both positive and negative lines running from the starter battery to the DCDC charger. Is it possible to just wire in a negative line to the chassis of the TV (near the hitch) and run that along side the positive line from the starter battery? I would use a dual pole plug & socket like the Tectran recommended earlier in the thread.
I would not have an issue with using the frame as a ground.(just make sure battery to frame cable is adequate.)
Also, I would wire in a fuse or breaker on the positive feed near the starter battery. Is a 60 amp ok for 6 AWG wire? What is preferred, breaker or fuse?
If you used a breaker, you would not need to carry a spare. Either will work.
Finally, there are dip switches on the charger that customize the charging profile of the battery bank. Considering I'm using flooded GC2 6 volt batteries, what is the recommended absorption and float "end-of-charge" voltages for my configuration?
If it were me 14.7 and 13.2(you could bump up to 13.5 or 13.8 if you are using a lot of power.
2019 Ford F150 EcoBoost SuperCrew
2016 Rockwood Mini Lite 2504S. TM2030 SC2030
640 Watts Solar. Costco CG2 208 AH and Lifepo4 3P4S 150 AH
Renolgy 40amp DC to DC charger 400 Watt and 2000 Watt Inverter's hard wired.
Boondocking is my Deal
CJM1973
Trenton, MI
Posted: 11/07/19 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks a bunch. AWG cable, breaker, plug ends, and DCDC charger are on their way. Hopefully, the weather holds out so I can get this project behind me before thanksgiving.
mapguy
Puget Sound
Posted: 11/07/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry - late to the party....
Personally, I prefer external regulation/control on non ecu controlled vehicles. Check the link for info...this is one source.
https://alternatorparts.com/quicktifier-external-bridge-rectifier.html
details of how this works has been detailed by Mexicowanderer here many times.
CJM1973
Trenton, MI
Posted: 11/07/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting. I will investigate.
Rbertalotto
Massachusetts
Posted: 11/10/19 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like there is loads of miss information on this thread....About hooking a DC to DC directly to the Alternator....NO
About mounting the DC to DC at the trailer... I don't think so
Check out this excellent video of realtime testing of Renogy DC to DC
https://youtu.be/EcVjPap9dkY
RoyB
Dartmouth, MA
2018 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
420w Solar / Bogart SC2030 / Trimetrics
CJM1973
Trenton, MI
Posted: 11/10/19 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Seen the video. Everywhere I've read says to mount the dcdc charger closest to the house batteries. Haven't read otherwise.
Rbertalotto
Massachusetts
Posted: 11/10/19 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Well...Learn something new every day.....Looking at Renogy Install Manual
"When selecting a location for the DCDC, make sure that the unit is as close as possible to the battery you will be charging (auxiliary battery). "
I had read on a few other sites to put it close to the main battery.....Don't trust everything you read on the internet.. :-)
CJM1973
Trenton, MI
Posted: 11/10/19 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I learned early on that there are a bunch of liars on it...except for maybe RV .net. [emoticon]
I bought a water proof tongue box that I will install it in along with my 3 AGM 100 AH batteries. Between the new battery bank and this new DCDC charger, I our Alaska trip will be less reliant on firing up the old inverter generator. I'm bringing one just to be safe.
Rbertalotto
Massachusetts
Posted: 11/10/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I ordered the Renogy 40A version to charge my portable battery box I just built for my Roof Top Tent....and to charge the trailer batteries when I'm pulling that unit.
These DC to DC chargers are really neat...Lots more control and safety for your alternator and your batteries that a simple solenoid like we used to do.
With my 2018 RAM I understand that a simple solenoid setup will confuse the computer controlled alternator but these DC to DC chargers are fine....
We shall see!
You can see my Portable Battery and RTT solar here:
www.rvbprecision.com
time2roll
Posted: 11/10/19 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
All charging systems work better when close to the battery getting charged.
Solar, converter, alternator, and this Renogy dc/dc charger.
675w Solar pictures back up
Page of 5
