RV.Net Open Roads Forum: Tech Issues: Brake light/ turn signal
 > Brake light/ turn signal
tensch
Long Beach, CA
Posted: 11/05/19 09:04am Link  |  Quote  |  Print  |  Notify Moderator
I am having an issue with the passenger side turn signal and brake light not working on a 1993 Coleman pop up. The running light is working. I'm just wondering where to start with this and maybe there is a simple fix or test? It is a 4 pin connection and I have replaced the bulb. Thanks.
Bobbo
Wherever I park
Posted: 11/05/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Broken wire somewhere. Easiest just to run a new wire. Butt connector (weatherproof) it at the light and at the 4 pin connector.
You can try to track down the break, but why bother. Running the new wire is easier.
Another possibility is the socket is bad, but I am betting on the wire.
Bobbo, Linda and the furry kid (45 pound rescue)
schlep1967
Harrisburg, PA
Posted: 11/05/19 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Start with a multi-meter or test light on the vehicle side of the 4 pin connector. If all is good there try cleaning the 4 pin connector. After that, a quick visual inspection of any wiring you can see for cuts or breaks. Then do as stated above, run new wires.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 11/05/19 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Get a cheap 12 volt test light. Less than $10 and more forgiving when chasing tail light.
You need to make a good ground somewhere. Use a scrap piece of wire if necessary. Once you have the alligator clip connected to a good ground you can probe the socket first since you changed the bulb. You could easily have purchased the wrong bulb or not have it inserted properly. A simple test is to remove the same bulb from the left light and put it in the right side. Test your old bulb in the left side as well.
If you still have the issue then you should really start at the trailer plug side of the tow vehicle. Could be a blown fuse in the towing vehicle.
You need to be careful to not introduce a new problem while trying to diagnose this one. Take pictures as you go and print some out. Document what you did.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
enblethen
Moses Lake, WA
Posted: 11/05/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
What is the tow vehicle?
If it is the F150, check for blown fuse in the fuses under the hood.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cavie
Posted: 11/05/19 11:58am Link  |  Quote  |  Print  |  Notify Moderator
START WITH THE BLUB.Turn and break are the same filament of an 1157 bulb. Unplug from TV and check TV plug. Disconnect trailer wiring from light. Plug in TV and check trailer wiring. Yellow and green are turn signal. Red is brake, white is ground.
Terryallan
Foothills NC
Posted: 11/05/19 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Agree check the bulb. however you said the running light is working. But that doesn't tell you the brake light is working. The brake light, and the turn signal light is the same bulb. has 2 filaments in one bulb.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
opnspaces
San Diego Ca
Posted: 11/05/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
I'll bet the cheap light socket is not touching the base of the bulb. Try putting the turn signal on and then go push the bulb tighter into the socket. you can also remove the bulb and look down into the socket. It might be possible to bend the two electrical tabs up a bit so they make better contact when the bulb goes in.
I had a similar issue in on my 1986 and I could temporarily fix it by bending the tabs. In the end I had to pull the whole back panel down and replace the lights with some LED taillights.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
opnspaces
San Diego Ca
Posted: 11/05/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
As far as simple tests, it kind of depends on your skill level and available resources.
Do you have a couple of alligator clip test leads? If so unplug your 4 flat plug and use one test lead to connect the ground pins to each other. Use the second test lead to see if the tow vehicle yellow (left turn) wire can blink the right turn by connecting from yellow (TV) to green (PU) If the light blinks the problem is in the TV, if the light still does not blink the problem is in the trailer.
beemerphile1
Ohio
Posted: 11/05/19 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Use a meter to determine if the signal is actually reaching the socket and report back.
The most common running/brake light problems on a trailer are bad grounds.
The brake/turn bulb filament is higher amperage and requires a solid ground connection.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
