RV.Net Open Roads Forum: Tech Issues: Brake light/ turn signal
 > Brake light/ turn signal
cavie
Posted: 11/05/19 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Terryallan wrote:
Agree check the bulb. however you said the running light is working. But that doesn't tell you the brake light is working. The brake light, and the turn signal light is the same bulb. has 2 filaments in one bulb.
tail light is one filament. Brake and turn is the other.
enblethen
Moses Lake, WA
Posted: 11/06/19 07:02am Link  |  Quote  |  Print  |  Notify Moderator
OP: Did you check for fuse in the truck? Each function has a separate fuse.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Terryallan
Foothills NC
Posted: 11/06/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Ain't that what I said???. Guess I wasn't real clear.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
BarabooBob
Baraboo, WI
Posted: 11/06/19 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Do yourself a favor. Run new wires and change your camper lights to LED fixtures. The total bill if you do it yourself can be as little as $60. I personally solder all of my connections and use heat shrink tubing to seal everything up.
Bob & Dawn Married 31 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
tensch
Long Beach, CA
Posted: 11/10/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Turns out it was broken wire at a plug that was about 3 feet from the 4 pin connector. It was wrapped in electrical tape so previous owner must have done a band-aid fix. Bought a new plug and everything is working. Thanks for all the help!!
opnspaces
San Diego Ca
Posted: 11/10/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Glad you got it fixed. And thanks for coming back with an update. I'm sure I'm not the only one who periodically checks threads he's made suggestions on to see the outcome. [emoticon]
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
