RV.Net Open Roads Forum: Tech Issues: no hot water electric or LP
 > no hot water electric or LP
pa bell
ohio
Posted: 11/05/19 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Suburban SW6DEL will not heat water with LP or electric. Stove and furnace work fine with LP. Not sure what to look for. Any ideas?
road-runner
Oregon
Posted: 11/05/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Does the gas flame ignite? If it does, check if the bypass valve is in the wrong position.
2009 Fleetwood Icon
Terryallan
Foothills NC
Posted: 11/05/19 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
honestly. sounds like the Mother board, or a bad thermo sensor
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
AllegroD
Outdare
Posted: 11/05/19 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
There is likely a fuse in the fuse box.
Wherever I happen to park
Posted: 11/05/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Since I do not have a Surburan this is part conjecture but as I recall it's really two entierly seperate systems in one box.
The 120 volt system consists of the breaker back at your power distribution panel, wire to the water heater A pair of thermostats (primary and hi-temp) Switch and heat element. it has NOTHING to do with the Propane system
Which has a control board. two more T-Stats, and all the gas valves and ignition stuff.
Home is where I park it.
pa bell
ohio
Posted: 11/05/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
The gas does not try to ignite. Not sure this model has a mother board or is there a mention of a thermo sensor.
DutchmenSport
Indiana
Posted: 11/05/19 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Had a similar problem years ago on my previous camper. Turned out to be the thermostat (not the one on the wall of the camper, the one on the water heater itself). However, I did take mine into a shop and they fixed it. I would have never figured it out myself.
pa bell
ohio
Posted: 11/05/19 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
The unit only has 2 t-stats, one for each LP or electric. Not sure if this is right but the reset on either t-stat does not physically move or click when pushed.
Also the 120v breaker is ok.
BFL13
Victoria, BC
Posted: 11/05/19 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Does the red light come on when you turn on the switch for using propane heating?
That whole side needs 12v to work the switch and the control board to operate on propane.
If the red light comes on you have 12v to the switch, but the switch might be bad. (or downstream the control board might be bad) Pull the switch out and get at the back of it to jumper the wires to see if now the burner lights. No joy, next get at the control board to see if it has any 12v.
Can't remember if the Suburbans need 12v to operate on 120v.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
opnspaces
San Diego Ca
Posted: 11/05/19 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
The SW6D is a direct ignition water heater with no pilot light. Are there any symptoms when you try to light on Propane?
Is there a light illuminated on the power switch in the RV?
If you turn on the water heater do you hear or smell any propane?
Do you hear the igniter clicking or sparking?
Do you have a digital multimeter to check for power at various places?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
