RV.Net Open Roads Forum: I take back all the good stuff I've said about Les Schwabs!
Search only in Tow Vehicles
 > I take back all the good stuff I've said about Les Schwabs!
Page of 8
ksg5000
Oregon
Posted: 11/06/19 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Manager got red faced pizzed with me when I would not accept the repair for free.
I bet LS was glad that you no longer do business with them. Fixing stuff for free is generally considered a "good thing".
Kevin
FishOnOne
The Great State of Texas
Posted: 11/06/19 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Turtle n Peeps wrote:
LS used to be a great outfit. Since the old man died it went down hill fast.
The other day my car tire was low on air so I stopped by LS and left my car there so they could put some air in one of my tires. I went to pick the car up and the girl said they did not put air in my tire. I say what the hell? She said let me get the tech.
The tech came out and said I couldn't put air in your tire because it was "so dangerous." I'm like ok.
So I get home and take a good close look at the tires. There is nothing dangerous about ANY of them. Where they wearing perfect? Nope, but they for sure worn't low on tread or dangerous.
Of course he wanted to sell me tires. I won't go back there because of that.
Like I said. Things changed a lot since the old man died.
LOL... Come on Turtle so you took your car to a tire store just to add some air? And you even left your car for them to do it?
Did I get this right? Tell me I'm missing something here! [emoticon]
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
FishOnOne
Posted: 11/06/19 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Sooo, in my 8 years up here in the PNW, generally had pretty good luck with Schwabs. Lots of fleet vehicles, so plenty of truck tires, brakes, patch a loader tire at 1am stuff.
Last night I drop off my company pickup AFTER calling earlier in the day to confirm they could do what I needed. Shocks, brake pads (maybe rotors but likely not), oil change, balance and rotate tires (Schwab Toyos).
Guy calls me this morning to go thru the work needed. Shocks/struts, 1 blown 1 leaking, check. Brakes, pads low on both axles, check.
Rotate and balance, check. We don't do oil changes! WTF? Guy yesterday said no problem....ok whatever.
How much? Shocks/struts, $900 something, ok good. Brakes? $2100!
Again WTF? Sir we only replace ALL components. Pads, caliper and we will see if it needs rotors...
Huh? It's a 3 year old truck, no need for calipers. Sorry that's our policy.....
Gd@mmit. Now I gotta make like 3 separate service appointments. 1 for the shocks 1 for the brakes and probably 1 for the oil change separate.
And to boot, drove my personal truck to work and clipped a limb that was sagging and cut off protruding into the shoulder, smashed my passenger side mirror at 6am in the fog.....
Les Schwabs can kiss my @ss.
Anyone know who else sipes tires in the Seattle area? That's the only need I'd have to go back there. Since they now won't mount non Schwab tires either.
You could of had all that done at a GM dealer. Not sure about the siping part since we don't have that service here.
Just an fyi for a cost comparison I had a brake service performed on my truck today which included brake pads, clean and lubricate calipers, rotors turned and brake fluid flushed for $1,200 at a Ford dealer. I also purchase tires from this same dealer as they will price match Discount Tire. One stop shopping is the best way to go.
Cummins12V98
on the road
Posted: 11/06/19 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Guess you don’t understand my point. Simply put I don’t take advantage of people.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 11/06/19 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
That’s an insane price Fish.
fj12ryder
Platte City, MO
Posted: 11/06/19 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
You must be joking, you can't be serious.
Howard and Peggy
"Don't Panic"
FishOnOne
Posted: 11/06/19 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Your right... I went back and looked at the receipt. It's $299.95/axle so it was ~$600 total. I was thinking $600/axle. [emoticon]
Turtle n Peeps
California
Posted: 11/06/19 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
Not at all. I work about 100 steps away. They were busy and I said fine, I'll come back at lunch and tossed them my keys. I came back and.........well.......
That's fine. I'm fleet manager of a small fleet of gov vehicles. I use to recommend them to my boss to go there.
Not anymore.
Anybody know if the techs work on commmission? I got the feeling this guy did. If so it all makes sense now.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
2012Coleman
Posted: 11/07/19 05:05am Link  |  Quote  |  Print  |  Notify Moderator
With tires, it's always a good idea to shop around. In my case, I save a little over $400 on top of the line Michelin's for the wife's car at Costco - Discount Tire is usually my go to place. And I thought I had a good service place until months after having it there for service which required them putting it on a lift, I found both rocker panels crushed under the rear doors. The side steps concealed the damage. 2K to get it fixed, can no longer prove that this shop did it.
My advice, if your truck has been on a lift, check it thoroughly before leaving.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
FishOnOne
Posted: 11/07/19 05:38am Link  |  Quote  |  Print  |  Notify Moderator
Not anymore.
Ok.... You had me worried there for a bit
Page of 8
