RV.Net Open Roads Forum: Full-time RVing: Full-time in the Arizona heat
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Full-time in the Arizona heat
jackM85308
Apache Junction
Posted: 11/05/19 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone stay full-time in an RV park in Arizona during the heat of the summer if so what did you do to stay comfortable?
midnightsadie
ohio
Posted: 11/05/19 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
well my brother inlaw lives down the road in tempe during the summer he doesn,t go out in the day time. but like any place cold or hot you get use to it.
westernrvparkowner
montana
Posted: 11/05/19 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Have air conditioning, and lots of it. Be prepared to pay a pretty penny for electricity. An evaporative cooling system might also help.
accsys
Green Cove Springs, FL
Posted: 11/05/19 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on where you are staying. We spent last summer (April thru September) in Prescott Valley and easily weathered it. It did get hot (95-100°) during July and August but our two A/Cs handled it well.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350 (Mothership)
2004 Liberty Renegade 4x4 Toad (Libby)
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
TechWriter
On The Road
Posted: 11/05/19 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't have two ACs, I wouldn't do it. You might be able to install a swamp cooler in an RV window.
Buy an autoformer because sure as shooting the park voltage will dip during the summer months.
If you have a dog, buy pet shoes otherwise you risk burning the dog's feet.
If possible, try a summer getaway to a mountain campground (> 7000') as it's cooler up there.
Keep in mind that when the summer monsoons hit, it becomes very humid as well as hot.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
Janss
Sedona, AZ
Posted: 11/05/19 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Use awnings if you can. You may have to run your AC 24/7...in Phoenix (or AJ) it can be 90 degrees at night.
Like others wrote, best to head to higher elevation...within AZ if you want to stay close.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
jackM85308
Apache Junction
Posted: 11/05/19 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Couple people told me they install small window AC units and they say that really does the trick much more efficient and less costly anyone ever tried that?
BarbaraOK
On The Road
Posted: 11/05/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
All of these come with wheels. At the very least, head up to Payson or Flagstaff for the summer.
Barb & Dave O'Keeffe - full-timing since 2006
Figment II (2002 Alpine 36 MDDS) ">
2018 Ford C-Max HYBRID
FMCA - F337834, SKP #90761
Our Blog
azdryheat
Tucson, AZ
Posted: 11/05/19 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Arizonans leave for the summer.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
bobsallyh
Livingston, TX.
Posted: 11/05/19 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Depending how big your rig is determines a lot. 2 roof ACs in a large unit will be marginal. A friend of mine has 32' Artic Fox fiver. He put a window unit in and it made a big difference plus was much more efficient. Silver bubble paper in the windows also helps, the only drawback is it's like being in a cave. Put Styrofoam in the roof vents and put silver bubble in the shower dome. Never leave with your awning out. Wrap your water hoses with pipe insulation. You won't need to run your water heater. Also foam insulation on slide roofs helps keep some of the heat from the slide. The park has about 156 sites and about 8/10 fulltime residents.
