RV.Net Open Roads Forum: Technology Corner: HDMI outlet.. Ideas??
 > HDMI outlet.. Ideas??
ItsyRV
Desert SW
Posted: 11/06/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
DD716TED wrote:
I am looking for something that would be in a covered plate to protect it from road water / elements..
That was an example of the various configurations of standard communications/media plates. Any standard exterior RV electrical outlet cover sold in every RV, boat, home improvement or online will cover the plate and make it weather tight.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
RoyB
King George, VA
Posted: 11/06/19 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
You can view HDMI WALL BOX panels from AMAZON as well... I have run some pretty long HDMI cables with good success...
Roy Ken
DFord
Near St Louis, MO
Posted: 11/06/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you've got a Dish Wally receiver. You can convert the composite - AVI (Yellow-Red-White) outputs to use the coax cable (channel 3 or 4) or you'll need to run an HDMI cable to the outside.
You could use this device to convert the signal:
https://www.amazon.com/CIMPLE-CO-Composite-Converter-Modulator/dp/B06XC9Y3VB/
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
valhalla360
No paticular place.
Posted: 11/07/19 05:53am Link  |  Quote  |  Print  |  Notify Moderator
DD716TED wrote:
valhalla360 wrote:
That or if it's a newer TV, have you considered wireless?
not that new of TV
If it's got HDMI, there are wireless dongles that can work.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
CA Traveler
The Western States
Posted: 11/07/19 06:16am Link  |  Quote  |  Print  |  Notify Moderator
I had 2 TVs connected over coax via the composite output (3 RCA jacks) at home. Usable but the pictures weren't the best. Changed the kitchen one to HDMI over coax with significant pic quality improvement.
The pic/sound is delayed (a little less on the HDMI TV). The great room and kitchen TVs are open and close and the sound delay is annoying so the kitchen sound is turned down. This should not be a issue with a outside RV TV but may be with multiple inside TVs.
I'm sure the delay occurs in the receiver outputs and not the converters.
2014 Grand Cherokee Overland
Bob
LittleBill
Scranton, PA USA
Posted: 11/07/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Would something like this work?
Protected hdmi
