RV.Net Open Roads Forum: General RVing Issues: Loose doors and cabineet panels
 > Loose doors and cabineet panels
down home
south
Posted: 11/06/19 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Our RV is now 14 years old. The cabinets and doors are solid wood.
Well...here in the land of it's a dry heat...and cold of Az. The bathroom door won't stay closed going down the road and all the panels in the doors are loose.
Tech says the wood is drying out. Wippee another problem to deal with.
Says the factory uses not even dried woods and seals it.
Well now it is shrinking. So bucket of water in shower and full toilet bowl of water. But ac will suck all that up in n time.
pianotuna
Regina, SK, Canada
Posted: 11/06/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
I used water thin CA glue for wood to deal with loose panels. That was in 2009. They are still just fine.
A bungee cord on the bathroom door works for trundling down the road.
Regards, Don
Etstorm
Frankston,TX
Posted: 11/06/19 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
On the cabinets you may can use fine grit steel,wool and boiled linseed oil
rockylarson
Jersey Shore
Posted: 11/07/19 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Once a Year... <<-CLICKY
Cabinets and doors still looking like new after 15 years. Replaced a few handles in the bath and kitchen that get a lot of use.
* This post was edited 11/07/19 01:49pm by rockylarson *
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
beemerphile1
Ohio
Posted: 11/07/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Do not glue the panels or they will split. They must be able to move but if they are so loose as to rattle maybe a high quality clear elastic caulk on the inside.
The door should be able to be adjusted.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
