ENG2242
Missouri.
My stabilizing jack and slide outs operate on hydraulic. I retracted the slides and it quit operating. There is a selenoid with heavy gauge wire attached to it near the pump, that clicks on and off when power is sent to it. However, no hydraulic activation. I don’t have schematics to refer to. Plenty of power to the selenoid, I tried tapping it and jumping it, no luck. Suggestions please!! Also is there any way to manually operate the two front stabilizers to raise and lower in order to hookup?
Thanks, David
David Hartmann
2018 Bighorn 3870FB
2007 Dodge Ram 2500 CTD 5.9
Prodigy 2
Auto-Slide Hitch
Firestone Air-Bags
BFL13
Victoria, BC
Heartland manual says the front hydraulic jacks and the hydraulic slides will have manual overrides. Says check manual from maker of the slide out for how to do that. Says for the front jacks, use the crank into the "alignment tube" up front.
They use the term "stabilizer jacks" for the ones at the back of the trailer
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
enblethen
Moses Lake, WA
Verify the main fuse is good.
Just because the solenoid clicks doesn't mean you have main power to it.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Edd505
Elephant Butte, NM
The pumps 12V, check the battery and make sure it has full charge. Likely you have the LCI Ground Control 3.0. Here's the manual with trouble shooting: https://support.lci1.com/ground-control-3.0-support-ground-control-3.0-onecontrol-touch-panel
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
ENG2242
Missouri.
Figured it out!! There is an extremely difficult breaker to find!! Finally after much investigation I found it and it had an extremely small reset lever on it. Reset and all is working well!!
enblethen
Moses Lake, WA
Thanks for the update!
romore
Okanagan valley British Columbia
Thanks for letting us know.
garyemunson
Reno, Nevada
Where was it? Some of us may have the same RV.
ENG2242
Missouri.
The breaker could be located anywhere in the hydraulic compartment. It was an son of a booger to find. Mine was three feet away from the pump against the front wall behind a bundle of wires. Apparently, they can place it anywhere. I will post some pictures when I get set up at my destination.
