RV.Net Open Roads Forum: Truck Campers: Pick up for TC
 > Pick up for TC
Page of 6
GAR2
Illinois
Posted: 11/09/19 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Hello intraveno, I’m going to go at this from a different angle than the others unless I missed something already stated. No experience with Dodge Cummins (I have a 2002 F350 Power Stroke 7.3L. What I would recommend (from experience) is looking at the bed support channels- Ford are notorious for rotting, not sure on the Dodges. I removed my bed and replaced the channels myself- no big deal as I have the shop and tools to do it.
The other thing, personally I wouldn’t trust the 5th wheel rails bolts. When I removed the old bolts (twisted off with breaker bar and 5’ cheater pipe because they were seized up) I found that the bolts were wore 1/3 of the way through where they went through the ‘L’ brackets attached to the frame. Just saying- something to check in case you do decide to pull a 5ver later on down the road. My truck was 17 years old, yours has a few more years on it- but I like the older trucks...... best of luck.
In the market to buy a T/C
2002 F350 4wd CC DRW 8’ box
Load Lifter 5000 rear air bags, front Timbrens
Rancho 9000 shocks
Brighton, Illinois
Posted: 11/10/19 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
^Good call on checking for rust, but that's the beauty of the truck the OP is talking about. Said never driven in winter and oil coated.
Since we haven't heard back from him, hopefully he's out doin burnouts in his new camper hauler!
djg
Caledonia, On
Posted: 11/11/19 08:38am Link  |  Quote  |  Print  |  Notify Moderator
As for older trucks I bought a 95 Ford F-350 duelly 4 years ago with 192000 miles on it well oiled down south truck wouldn't think twice about jumping in it and doing a cross country run with the camper. I've probably rebuilt the whole truck but it's cheaper than a new one and no emissions, as for sticker weights in Ontario they go by axle weights as per DOT as I have checked and as long as you increase the carrying weight on your ownership you are good GVWR means nothing to them as long as you don't go over GVAW weights. (Call your local DOT in Quebec and ask them)
Dave
2015 Livnlite Camplite TC10
1995 Ford F-350 dually 7.3 Diesel
jaycocreek
Idaho
Posted: 11/11/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I agree..I did the same with my old 3/4 ton '76 Ford with the 390..Almost totally rebuilt from end to end..I to would not have hesitated to head anywhere in that one..And no emissions necessary..
New or newer trucks are nice but the cost of repairs anymore is unbelievable,especially with a diesel..
Kayteg1
California > Nevada
Posted: 11/11/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
That's why you have 5 years/100k miles factory warranty before you can consider extended one.
DPF and DEF systems were scarry 5 years ago due to lot of "baby teeth" and mechanic's learning curve.
Now not only we have lot of DPF regeneration shops, but mechanics know how to fix it.
Main progress was ScanGauge developing X-gauges who will tell you soot level and DPF regeneration status, so you can avoid main problem of cutting regeneration short.
Bare in mind that in commercial use the DEF equipped engines logged million miles.
The only thing that sucks is manufacturers milking customers by SCN coding, but we fight back with https://repair.org/stand-up
ajriding
st clair
Posted: 11/13/19 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
If you are looking for a Roamer TC I know where you can get one at a premium price
burningman
Seattle, WA USA
Posted: 11/14/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Good luck calling the dealer for help with a new, over-computerized truck fritzes out in the middle of nowhere.
Simplicity IS reliability.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Kayteg1
California > Nevada
Posted: 11/14/19 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
rright!
intravino
Quebec
Posted: 11/14/19 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all of your replies.
I had some personnel business to attend lately, so I had no time.
I called the owner and I have to go see it during the weekend.
Thanks,
Intravino
intravino
Quebec
Posted: 11/17/19 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Update on the Cummins pickup.
I called the guy for an appointment and asked him more details questions (thanks to the replies form members here); the injection pump is due, the auto transmission is slipping and plus there is a werid noise from the differential.
Too good to be true. I passed on going to see it.
I will look more into a gas engine.
Thanks again for all of your replies.
Intravino
Page of 6
 > Pick up for TC
