RV.Net Open Roads Forum: Travel Trailers: Battery storage
 > Battery storage
jamesu
Camano Island, WA
Posted: 11/07/19 05:59am Link  |  Quote  |  Print  |  Notify Moderator
Over the years I have taken out my TT batteries and hooked them to a trickle charger in my garage during each winter. I now have the TT under covered storage at a local storage yard which has electric plug ins. Related to my TT battery’s winterization, am I good just plugging in the TT? Will this keep the battery warm/charged? Or should I remove the battery and trickle charge it in my garage?
My storage facility is open-sided, covered storage so there is no heat, just an electric plug in next to my TT. I can count on a few decent freezes in December/January here in W. Washington. Other than this battery question, my TT is stowed and winterized.
2011 Chevy 2500 Duramax diesel
2019 Timber Ridge 24RLS (Outdoors RV)
Go Cougs!
Lynnmor
Red Lion
Posted: 11/07/19 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Instead of powering up the converter and any parasitic loads, I disconnect the battery and use a Battery Tender for a few days a month. It could be left on indefinitely, but I have other uses for it. With the trailer plugged in it is exposed to any electrical glitches in the power system. Cold will not harm a fully charged battery, in fact cooler temperatures are better for it.
* This post was edited 11/07/19 01:57pm by Lynnmor *
CA Traveler
The Western States
Posted: 11/07/19 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Ideally any charger should be temperature compensated but most aren't.
2014 Grand Cherokee Overland
Bob
GrandpaKip
Flat Rock
Posted: 11/07/19 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Our camper is plugged in continually when at home. Never had any problems with batteries.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
rbpru
North Central Indiana
Posted: 11/07/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
I have left the TT plugged in all winter, checking the battery water level, I have disconnected the battery and charged it periodically on the TT. However, the easiest way for me is to charge it and leave it in the laundry room in a plastic tub.
It is convenient to check but only sits for 3-4 months so it rarely looses much charge.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
opnspaces
San Diego Ca
Posted: 11/07/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
If the battery is fully charged it will be fine to sit on the trailer all winter disconnected. If you still want to charge it I would plug disconnect it from the trailer and plug the tender into it.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
pianotuna
Regina, SK, Canada
Posted: 11/07/19 11:40am Link  |  Quote  |  Print  |  Notify Moderator
so long as battery is fully charged and disconnected the colder it is the better for the battery.
Regards, Don
profdant139
Posted: 11/07/19 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
So I am going to display my ignorance, once again -- I had thought that if a battery is left disconnected, it will discharge about one percent per day. And after a couple of months, that discharge could shorten the battery's useful life.
Is that not true? Because if a battery can be charged, disconnected, and left alone for a long time with no damage, I am wasting electricity. I store mine in my garage (which never freezes) and keep it on one of those Battery Minder Plus gizmos.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
garym114
Bluff Dale, Texas
Posted: 11/07/19 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
Instead of powering up the converter and any parasitic loads, I disconnect the battery and use a Battery Tender for a few days a month. It could be left on indefinitely, bit I have other uses for it. With the trailer plugged in it is exposed to any electrical glitches in the power system. Cold will not harm a fully charged battery, in fact cooler temperatures are better for it.
Best advice
The lower the temperature the lower the self discharge rate.
You really don't need a tender on a disconnected battery but you can connect one periodically if it makes you feel good.
Lynnmor
Red Lion
Posted: 11/07/19 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that some trailers have a "disconnect" switch that doesn't completely disconnect everything. If you don't know for a fact that everything is disconnected, take off a battery cable.
 > Battery storage
