RV.Net Open Roads Forum: Cummins 5 year old synthetic oil with 1000 miles - change ?
 > Cummins 5 year old synthetic oil with 1000 miles - change ?
Mojave, Kern County, California
Posted: 11/07/19 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Being 75, sick, broke and driving just a few miles isn’t the issue. Maintenance is maintenance.
olfarmer
Iowa
Posted: 11/07/19 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I say go for it, it will be fine. As for the tires if they are less than 10 years old I wouldn't worry about them. I have had tires older than that with no problems, look at the condition, if they are cracked or weather checked then they need to be replaced! Most tire companies say 10 years if they are in good condition. On edit. I missed the 10000 miles on the oil. I wouldn't drive anything 10000 miles on an oil change whether it is synthetic or dino. I think that is just too far! I would say 5000 with syn oil. 3000 with dino oil.
* This post was edited 11/09/19 11:43pm by olfarmer *
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
ScottG
Bothell Wa.
Posted: 11/07/19 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I can't see how anyone can say it's OK to put 10K miles on that engines oil without knowing waht exact eng and year it is. A lot of Cummins engine didn't have anything near a 10K mile oil change interval.
As far as the acidic thing and old oil, I don't buy it. I once let an old car (1964 Thunderbird) sit for roughly 6 years and then I rebuilt the eng. The bearings didn't show any signs of being eaten by acid.
I can see the reasoning behind the theory but in pratice it doesnt seem to be an issue.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Chum lee
Albuquerque, NM
Posted: 11/07/19 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Normally I'm not a fan of testing oil, (in lieu of changing it) but in this case, he could spend +-$40.00 and have the oil tested by a lab to see if it's fit for continued use.
Or there's the oil blotter test using a clean white business card for free.
https://www.machinerylubrication.com/Read/499/blotter-spot-method
Chum lee
11178adm
nw mo
Posted: 11/07/19 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
I would at least change the filter. if there was any moisture in the oil it could have caused the paper to deteriorate in 5 years. acid in the oil is'nt the problem that it was in the past due to ultra low sulfur diesel
grldst
Dallas, GA
Posted: 11/07/19 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
I know very little about synthetic oil, just wondering does synthetic age or break down with age as much as real oil?
Ivylog
Blairsville, GA and WPB, FL.
Posted: 11/08/19 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Use the oil but I’d worry about the tires.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
twodownzero
NM
Posted: 11/08/19 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I sent my oil in for analysis after ~4 years and 14,227 miles and it was still perfectly fine and I could have left it in there.
sundancer268
Charlevoix
Posted: 11/08/19 10:13am Link  |  Quote  |  Print  |  Notify Moderator
My oil is going on 5 years and last year I only put on about 350 miles. Blackstone labs says to keep going as the oil is good and I am running Dino, not Syn. I would not worry about it especially for the short haul though I would put enough miles on it during the moves to get the engine and oil hot, maybe a 30-45 minute drive on the highway and not city streets.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2019 Jeep Cherokee Trailhawk Elite
Road Master Sterling All-Terrain, Airforce One
rgatijnet1
Posted: 11/08/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
I would be more concerned about the tires sitting for so long than the oil. I would forget about the oil and drive a little slower than normal to get to the destination. Of course you want to make sure that the tires are properly inflated with maybe some extra to keep them cooler. After the engine warms up it will burn off any moisture that has gotten in to the oil.
