RV.Net Open Roads Forum: Truck Campers: Upgrade truck suspension
 > Upgrade truck suspension
Page of 5
otrfun
On The Road
Posted: 11/08/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
OP, have you tried removing the upper Stableloads to see if it reduces the "hobby horse" effect? I'd try this before purchasing new shocks for a new truck. Most folks seem to have good luck with the uppers, but some folks (including a friend of ours) did not. If the upper Stableloads are the culprit, you may want to try installing the Torklift lower Stableloads instead.
PhilR
Albany NY
Posted: 11/09/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Interesting....I have an 8-11 on a 2019 Chevy 3500 Duramax with upper stableloads and did a 6,000 mile round trip from NY to MT last spring and did not experience that problem. I guess every truck camper combo has it's own personality.
jaycocreek
Idaho
Posted: 11/09/19 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I have owned between 12-15 different truck campers and I can say with surety,that statement is 100% true from my experiences..
1994 F-350 DRW /460/k&n intake /415# torque/lance 9.6/Engel compressor fridge/3 gr 27 batteries/Honda 2k/Honda 3K/WH Camo 2250/Reese solid bar extension/Buddy heater/3 inverters//Happi Jack tie downs /Firestone bags/Yamaha Rhino/Winch and Lockers
Kayteg1
California > Nevada
Posted: 11/09/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
When each vehicle always will have different driving characteristics, this thread makes me wonder if certain makes are more prone to troubles, than others.
I had my heavy campers on 3 different Fords, including picking up 4300 lb camper with F250, what was serious overload and none of the Fords had handling issues with factory suspension.
ardvark
Bristol, TN.
Posted: 11/09/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
My 2012 F350 SRW LB is most often fine, but on some stretches, for example I35 coming out of Minnesota into Iowa and then on the Iowa stretch, it porpoises so badly you would swear the front end is going to lift off the ground.
I am within all the numbers in terms of weight and it made no difference whether it was our Hallmark popup or our Northstar Laredo. Ranchos help, Super Springs made no difference at all. Also had it happen on a very short stretch crossing into PA. from New York. When it happens, it is instantaneous. The previous owner opted for plow springs on the front end, which is ridulous overkill considering what we have in the bed and I wonder how much that comes into play.
Again, just another work in progress.
Kayteg1
California > Nevada
Posted: 11/09/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Porpoisoning is also often problem on big motorhomes, who weight even 15 tons and from what I read, nobody can figure out the phenomena.
It is kind of mechanical resonance and resonance is hard to predict.
For example I have patio chairs, who on heavy wind and some clearance under foot will rock like crazy making whole house noise similar to earthquake.
noteven
Turtle Island
Posted: 11/09/19 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Pickup truck front ends bounce in the air in the commercials on tv.
JIMNLIN
Oklahoma
Posted: 11/10/19 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Pulling heavy GN trailers on a haulers website.....carrying a heavy truck camper on rv websites....pulling a heavy RV trailer on a rv website with any truck/trailer/truck camper combo shows any combo can/may have handling issues regardless of brands.
Having done all three with the same one ton DRW and SRW Ford/Dodge/GM trucks its very frustrating trying to find a solution(s) for that particular combo. What worked on one combo did nothing on another which is what we see on all those type websites where someone is looking for help.
Having a choice from eight different LDT's to carry a 10' 6" heavy truck camper between job sites we soon find the trucks wheel base has more to do with a easier ride/handling issues.....but we also found what worked on one may give another combo more issues.
noteven
Turtle Island
Posted: 11/10/19 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Four different campers on the older truck, current camper on both trucks - the only thing that consistently improved the ride from a “fore and aft” standpoint- overhead jiggle, vibration, hobby horse, porpoising and all the other names was hitching a trailer to the receiver hitch.
* This post was edited 11/10/19 07:30am by noteven *
ardvark
Bristol, TN.
Posted: 11/10/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I think I may have said earlier on, handling with a truck camper is more a matter of trial and error so taking a dogmatic position about any one solution can be a mistake. And since the problem with our combo is not constant occurring only on relatively small sections of roadway, making adjustments here in N.E. Tennessee tells me virtually noting about how it will handle in other areas of the country. Quite a conundrum!
Page of 5
