RV.Net Open Roads Forum: Help and Advice on a badly placed 5th wheel
 > Help and Advice on a badly placed 5th wheel
Page of 7
Super_Dave
Harrisville, UT
Posted: 11/08/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Small forklift rental in my area is under $250 for a full day. A small Kubota is likely even cheaper.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Wiccedbug
Bad Spot
Posted: 11/08/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Yes backed out
Fisher Bill
Tigard
Posted: 11/08/19 11:25am Link  |  Quote  |  Print  |  Notify Moderator
This;
https://www.youtube.com/watch?v=j6qamcLAVaU
2006 Chevy 3500 Dually 6.6 Duramax Diesel & Allison Transmission
2010 Northshore 28RK by Dutchmen
Our first fifth wheel!!!
Edd505
Elephant Butte, NM
Posted: 11/08/19 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Fisher Bill wrote:
This;
Why?? Back under and move it!
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Fisher Bill
Tigard
Posted: 11/08/19 11:46am Link  |  Quote  |  Print  |  Notify Moderator
OP original post;
So I have a 35 ft 5th Wheel, that was put into a spot (barley) with a fence right on front of it. We had to improvise to get it unhooked but managed. Problem is now, the space between the fence and the hitch is not enough for any RV movers to even attempt to move this since they can't get their truck in there easily and we don't have any other option. Is there any way to pull this thing backwards 10 feet or so to make space for a truck to hook up? I was thinking come-a-longs to the back axle but I'm not sure of balance issues. If I bring the Jack's all the way up will the 5th wheel just fall forward if not hooked up to anything?
Edd505 wrote:
Fisher Bill wrote:
This;
ford truck guy
Pennsylvania
Posted: 11/08/19 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Fisher Bill wrote:
This;
He will not spend the $$$ to rent a forklift for the day, he sure as heck wont pony up for that.....
I'd remove the fence, grab the 5'er, replace the fence...
Or just rent a lift for the day
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
pyoung47
MO
Posted: 11/08/19 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
A pair of good quality car dollies under the jacks on a piece of 3/4 plywood might work. I’d prob then use a come along to pivot it around where it is accessible.
Wiccedbug
Bad Spot
Posted: 11/08/19 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
I appreciate the actual ideas. I should of originally posted as DIY methods without wasting cash As stated before.
1. Fence is not ours, no we cannot remove it plain and simple.
2. This is in Rockport Texas, the ground is sandy and usually wet and heavy equipment without a good weight dispersion will likely get stuck, including trucks. Pull it back 10-20 ft the ground stiffens up but hookup point is sand
3. The person that put it there a few years ago is no longer around. He only did it cause he really needed some cash. Movers as I've said will not do this, it doesn't matter if we pay them, they will not attempt it unless we can pull it back some more. Noone wants to work unless its easy work.
4. This place was directly hit by the landfall of Hurricane Harvey.
5. We are not the kind of people who dont have money to waste on moving something just 50 yards, the hurricane ruined us. We live in the RV, it's not a fun time road toy.
6. There's always a way to DIY if your not lazy and I assumed someone here would have done something similar before.
The physics of a well oiled sanded board seem sound. If it slides well it's not going to bend the jacks. I'm going to go with this method.
CA Traveler
The Western States
Posted: 11/08/19 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
In that case I'd use 1 1/4" tongue and grove subfloor plywood. 4 sheets, use 2 at a time. Jacks fully up.
If possible use side straps to keep the headpin straight.
2014 Grand Cherokee Overland
Bob
Thermoguy
Graham, WA
Posted: 11/08/19 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
you really need to post pictures if you want to get solid advice. Without that it is just speculations...
Page of 7
