RV.Net Open Roads Forum: Help and Advice on a badly placed 5th wheel
 > Help and Advice on a badly placed 5th wheel
Page of 7
JRscooby
Indepmo
Posted: 11/08/19 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Texas? Can you barrow some pipes? Lay down plywood, lay pipes across, then block or stack of blocks under the low part of frame. Crank up legs to put weight on blocks, and pull. Remember the pictures of the slaves building the pyramids? Any force to slide the legs has a lot of leverage to bend things. Better to hold low...
Chris Bryant
Arden, North Carolina
Posted: 11/08/19 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
The sand complicates things. Is rotating it a viable option, or must it be pulled back?
I would second the jacks fully retracted while moving. I’m thinking jacks on 2x6’s on pipes as rollers on plywood.
-- Chris Bryant
ACZL
UPstate,NY
Posted: 11/09/19 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Could the OP contact say the Army of local or nearest Army base to see if their air unit could use some practice w/ heavy lift by using a helicopter and move it for him?? I'm only asking/suggesting as it seems we've all gave pretty much same ideas 'cept this one. Know it's far fetched, but what the heck.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
sayoung
Tx
Posted: 11/09/19 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
It's way past photo time. One pic would clear up the whole idea of how to move or just abandon In place.
j2catfish
Newport, NC, U.S.of.A.
Posted: 11/09/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Unless that 5th wheel is a lot lighter than most, I do not see how the Legs can be fully retracted. I guarantee that if I raise my legs with out the truck under it, it will fall as fast as gravity will permit. Maybe your trailer is very light on the front over hang? I like the idea of auto rollers under the legs on strong ply wood but it still is a goat rope. Good luck with what ever you do.
(I was in Harvey also but nearer Houston.)
Regards,
Catfish
K3500; Teton Homes 5er;
Native Texan - Transplanted Tar Heel
Retired USMC Mustang (LDO)
Semper Fi !
Edd505
Elephant Butte, NM
Posted: 11/09/19 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Fisher Bill wrote:
OP original post;
So I have a 35 ft 5th Wheel, that was put into a spot (barley) with a fence right on front of it. We had to improvise to get it unhooked but managed. Problem is now, the space between the fence and the hitch is not enough for any RV movers to even attempt to move this since they can't get their truck in there easily and we don't have any other option. Is there any way to pull this thing backwards 10 feet or so to make space for a truck to hook up? I was thinking come-a-longs to the back axle but I'm not sure of balance issues. If I bring the Jack's all the way up will the 5th wheel just fall forward if not hooked up to anything?
Edd505 wrote:
Why?? Back under and move it!
What was used to put it in there then?? Use the same thing to get it out. Unless the fence came after he put it or had it put where it is.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
B.O. Plenty
Minnesota
Posted: 11/09/19 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
two floor jacks, the kind with wheels on them, on plywood sheets. Transfer the weight to them and slowly pull it backwards.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
JRscooby
Indepmo
Posted: 11/10/19 07:13am Link  |  Quote  |  Print  |  Notify Moderator
B.O.
I think a better idea would be block on 2-4 of the dollies we use to move cars around in the shop. We found a floor jack works if, and only if, you pull the jack. Push the car, car slides off jack or jack turns over.
Walaby
Georgia
Posted: 11/10/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Really don't understand why OP won't post at least one pic so we can get an understanding of exactly what the deal is.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
laknox
Arizona
Posted: 11/10/19 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
In TX, I can't believe that there isn't a neighbor with a tractor and 4-5k capacity front loader that wouldn't do this for a case of Lone Star and bragging rights. [emoticon]
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Page of 7
