RV.Net Open Roads Forum: Tow Vehicles: Banks Differential Cover
Search only in Tow Vehicles
 > Banks Differential Cover
LIKE2BUILD
Decatur
Posted: 11/08/19 07:23am Link  |  Quote  |  Print  |  Notify Moderator
A while back I came across a video series of Banks Performance testing differential covers. I thought it was interesting and very well done.
Now I see why. They've introduced the Banks Ram Air Differential Cover. I've already installed an AAM aluminum finned cover on my Ram 2500 so I don't really plan to change it out for this one. But, the science and engineering they put behind it are really interesting. They put a lot of time into measuring temps and air flow around the cover and observing oil flow inside the diff. It's really curious they purposefully extended part of the cover below the axle to grab air and flow it across the fins.
Maybe the new diesel emissions rules are clamping down on their business so now they are turning their attention to other performance enhancement options? [emoticon] Either way, the cover does look well designed and not just a show piece.
KJ
2012 Sandpiper 32QBBS--Sold ">
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (20, 14, & 12)
1 forgiving wife!!!
BenK
SF BayArea
Posted: 11/08/19 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for posting this very interesting diff cover
It might fit my Sub, as the others stick out and interferes with the tank skid plate
Was going to (maybe still going to in addition to this) just use a healthy dose of either Molybdenum Disulfide or Tungsten Disulfide
Issue with those super lube additives is with anything with friction clutches. Too slippery abd clutches will be ruined
Will check this out some more
-Ben Picture of my rig
Calicajun
Lancaster, CA
Posted: 11/08/19 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Watch the whole video and found it to be very informative.
Thanks for posting.
2014 Heartland Wildness 2775RB, 2015 Ram 2500 4x4 Mega Cab
time2roll
Posted: 11/08/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
I would not buy a cover that created a new low point to hit with a rock.
675w Solar pictures back up
dodge guy
Bartlett IL
Posted: 11/08/19 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
It doesn’t sit more than an inch lower than the diff itself, in fact the one in the video looked less than an inch. With that said. At the end of the video he showed what it would take to break off the fins. He also said that if it did break off you get a new cover for free. It’s meant to break away. And it won’t lose any fluid.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Owens River Road, California
Posted: 11/08/19 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I believe they work but they look very cool regardless. TY for posting.
LIKE2BUILD
Decatur
Posted: 11/08/19 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
That was a concern of mine as well. Did you see the part at the very end of the video where he addressed that situation? Fast forward to the 32:00 minute mark to see it if you didn't. Gale took a piece of steel rod and a 4lbs hammer and clobbered the part that hangs down. In his controlled condition the only thing that broke off was the part that hangs down leaving the rest of the cover in tact. He says directly if that happens, they'll give you a replacement.
Now, it's entirely possible the rock you hit will be funky breaking another part and allowing your gear oil to leak out. If that fries your axle will Banks cover it? Not sure.
I think they really intended this cover for on-road use trucks that are hauling heavy loads on the rear axle. Sure this could be used for an off-road truck, but the way they designed the fins and air intake it seems they are targeted conditions where the truck is at-speed flowing air across the cover and actively cooling the fins.
KJ
BenK
SF BayArea
Posted: 11/08/19 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
I don't off road much anymore, but I do...this is what I'd also install ir make myself
https://images.app.goo.gl/w7cSrG2rLjnUXpwj7
The stock diff covers also get peeled while crawling over stuff...seasoned off roaders know HOW2 manage that...but poop happens...
Turtle n Peeps
California
Posted: 11/08/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
This whole thing reminds me of a solution waiting for a nonexistent problem.
Kind of like people freaking out over 240F ATF temps. [emoticon]
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
FishOnOne
The Great State of Texas
Posted: 11/08/19 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Well said....
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
