RV.Net Open Roads Forum: Fifth-Wheels: winterizing black tank flush with air
 > winterizing black tank flush with air
dryfly
Posted: 11/08/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I've always been successful winterizing by just blowing air through my water lines. I know there is an anti-siphon valve in the black tank flush system. Will just blowing out this line clear water from it?
BB_TX
McKinney, Texas
Posted: 11/08/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it will just blow that water into the black tank.
DutchmenSport
Indiana
Posted: 11/08/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
I've done it that way on my previous TT. Never had a problem.
On my current 5er, I simply hook up the outside water faucet (sprayer, shower, blue coiled hose, hot and cold faucet) in my wet bay, to my black tank flusher (in my wet bay) then pump the pink RV antifreeze and watch for "pink stuff" to flow out the black tank outlet. Once it flows "pink" out the black tank drain, I know both the outside faucet and the black tank flusher line is winterized.
And by the way, I do this when camping too, so I don't have any dependency to hook up a garden hose to the black tank flusher.
Yosemite Sam1
Under the pines.
Posted: 11/08/19 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Unless it's full, I don't think it will do harm.
Pipes and water tubes burst with the expansion of water when it freezes in confined space.
Terryallan
Foothills NC
Posted: 11/08/19 08:47am Link  |  Quote  |  Print  |  Notify Moderator
This is what you want. No need to empty the black tank. In fact it is not a good idea to completely empty the black tank. You seals will / can dry out and start to leak. plus the dreaded dry tank smell.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
ScottG
Bothell Wa.
Posted: 11/08/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I just blow them out.
Our new TT doesn't seem to have any backflow device though...
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
ford truck guy
Pennsylvania
Posted: 11/08/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
I just blow mine out as well.. That just gets any standing water OUT of the line...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
MFL
Midwest
Yup, just blowing is fine. Are you sure it's not hidden Scott? I always thought this was required on a new trailer equipped with BTF? Mine is behind the shower faucet assembly, really hard to get at.
Jerry
Yosemite Sam1
Under the pines.
Posted: 11/08/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Water heater doesn't completely empty of water either with drain plug sitting a littler higher than the base of the tank. But it's insulated too so no worry.
schlep1967
Harrisburg, PA
Posted: 11/08/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
It probably does. I had the same issue of disconnecting the hose and water flowing back out. What I figured out is that the back-flow check-valve is on the other side of the trailer where the sprayer is attached to the tank. Behind the wall where I hook up the supply hose the line that goes over to the black tank goes up first. So when I disconnect the supply hose the water on my side of the check valve can still flow back and out the inlet. I simply added another check valve right behind the wall.
OP .... Sorry for the off topic right turn on the thread.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
