RV.Net Open Roads Forum: Fifth-Wheels: Wheel Bearings
 > Wheel Bearings
Page of 5
gmg
Houston, TX, USA
Posted: 11/08/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
We recently experienced a broken right side spring shackle. We actually drove about 500 miles on it before we discovered the problem. The trailer was sagging on the right side. The spring shackles were resting against the trailer frame. My question is do you think that would have caused any damage to the wheel bearings. The service guy that is repairing the suspension is recommending repacking the bearings due to our towing the trailer in that condition. What are your opinions. Thanks.
2013 Ford F-250 Powerstroke Crewcab; Pullrite Superglide Hitch; 05 Everest 294L 5th Wheel.
Busdriver
Shepherdsville Ky 40165
Posted: 11/08/19 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Repack & inspect
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
midnightsadie
ohio
Posted: 11/08/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
can,t hurt and should not be a big expense. p.s a new seal also and no china bearings put back in.
Cummins12V98
on the road
Posted: 11/08/19 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Doubt it caused any issue but if it makes you warm n fuzzy have at it.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Ivylog
Blairsville, GA and WPB, FL.
Posted: 11/08/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
What difference does it make if the trailer was leaning a little to the wheel bearings??? Pull the caps and if the grease is soft put the cap back on. If hard, put 90 weight oil in the cap and put back on.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
time2roll
Posted: 11/08/19 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
My opinion? Next he will sell you brakes and turn the drums.
675w Solar pictures back up
ScottG
Bothell Wa.
Posted: 11/08/19 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
There's no connection but if it hasn't been done in a long time and you want to spring for it, get them all packed.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Cummins12V98
on the road
Posted: 11/08/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
90 wt oil in the cap? That’s a new one.
fj12ryder
Platte City, MO
Posted: 11/08/19 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty much a temporary fix, after all grease is just basically oil in suspension.
Howard and Peggy
"Don't Panic"
Lynnmor
Red Lion
Posted: 11/09/19 12:52am Link  |  Quote  |  Print  |  Notify Moderator
The wheel probably was severely out of alignment and was operating with a side load on the bearings. The mechanic understands this and gave reasonable advice.
Page of 5
 > Wheel Bearings
