RV.Net Open Roads Forum: Tech Issues: extension cord length
 > extension cord length
scarecrow56
palm bay, fl
Posted: 11/09/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
I'm gonna put my TT in the back yard. I have used a 50' extension cord to power the slides and fridge and a few other things including the AC for a short time. Question is, This time I'm gonna have to use a 100' cord. How will this affect the voltage/drain on the power, if at all?
Chillin' in the sun, Palm Bay, Fl.
Dutch_12078
Winters south, summers north
Posted: 11/09/19 06:58am Link  |  Quote  |  Print  |  Notify Moderator
What size wire will the extension cord use? Is your TT 30 amp or 50 amp...
Dutch
2001 GBM Landau 34' Class A
wolfe10
Posted: 11/09/19 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Yup length AND wire gauge as well as load will determine whether your voltage drop is acceptable or "will let the smoke out" of you 120 VAC appliances.
If all you are running is a battery charger, smaller gauge can be used. If you plan to run high amp items like a roof air, a VERY different matter.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
SoundGuy
S Ontario
Posted: 11/09/19 07:24am Link  |  Quote  |  Print  |  Notify Moderator
If at all? [emoticon] Obviously the greater the current draw the greater will be the voltage drop. You also haven't mentioned the gauge of cable you plan to use - again obviously, the lighter the gauge the greater will be the voltage drop. You haven't provided any of this information, including the unloaded source voltage, so no one here can tell you what voltage drop you can expect. Measure your unloaded source voltage and plug numbers into this voltage drop calculator.
Cummins12V98
on the road
Posted: 11/09/19 07:56am Link  |  Quote  |  Print  |  Notify Moderator
12 ga at 15+amp draw is fine at 50'. 100' I would step it to 10ga.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
wnjj
Cornelius, Oregon
Posted: 11/09/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
It also depends upon how much wire there is in your house between the panel and the receptacle you’re using. Your best bet is to measure the voltage inside the RV with whatever appliances (e.g. A/C) running and step the cord gauge up if it’s not enough.
rhagfo
Portland, OR
Posted: 11/09/19 09:21am Link  |  Quote  |  Print  |  Notify Moderator
X2
This will fill your needs,but at a price!
Voltec 100' 10/3 extension cord
RJsfishin
Winston Or.
Posted: 11/09/19 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I always listen to the A/C,....if it has a good normal startup, it will be fine.
If it struggles to get going, get larger wire.
We lived in our MH for 5 months on a 100 ft 12ga cord. We could use the AC or the microwave but not both at the same time
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
rockylarson
Jersey Shore
Posted: 11/09/19 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Two 30amp RV extensions for under $120
* This post was edited 11/09/19 12:26pm by rockylarson *
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
MitchF150
Puyallup, WA
Posted: 11/09/19 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thing to do is turn all other electric off and then check what your voltage is at any plug. Then run the AC and then check the voltage at any plug. Even at 50', I bet you drop below 108v... While the AC is running, that low of voltage isn't doing your motor any favors, so...
For running anything else in the rig, you should be fine. It's the AC that will always tax the system to it's max, so gotta decide what you need to run and go from there.
I installed a dedicated 30a RV plug because when I ran my AC, it dropped my voltage to around 108v with only a 25' cheapie extension cord. Sure, I could have gotten a better cord, but decided to just go with the 30a setup..
Good luck!
Mitch
