RV.Net Open Roads Forum: Tech Issues: extension cord length
 > extension cord length
Terryallan
Foothills NC
Posted: 11/09/19 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
I use a 100' well now a 85' cord after the dog took 15' off of it. I run the AC, and fridge every spring to make sure it works for summer. don't run it long, Just long enough for the air to get cold, and I don't turn on anything else in the TT when the Ac is on.
It is the same cord I use to run the saws, drills, sanders, and lights in my work shop.
ask a "expert electrician" about doing it. He told me. If there isn't enough current to run it. It will simply trip the house breaker when the AC askes for more than it has to give. However. the cheap Walmart adapter does get hot, but the heavy duty Rv adapter does not.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
BFL13
Victoria, BC
Posted: 11/09/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
scarecrow56 wrote:
I'm gonna put my TT in the back yard. I have used a 50' extension cord to power the slides and fridge and a few other things including the AC for a short time. Question is, This time I'm gonna have to use a 100' cord. How will this affect the voltage/drain on the power, if at all?
Yes, voltage drop is the issue, and also popping the breaker in the house if anything big in the house on that circuit is also on.
Air conditioner can be damaged by low voltage, but other things might still run ok, but less well. Eg, microwave will run but struggle. The converter will run but at lower than rated amps. Your fridge will run on AC the day before a trip while on "cool-down" ok if you don't overload the circuit with other 120v things in the house or RV.
Your converter will be happy on Float voltage maintaining the batteries since that job is at very low DC amps so little voltage drop at the 120v level.
Comical about the dog! [emoticon] An "innocent" creature could not possibly do such a thing1
* This post was edited 11/09/19 05:42pm by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Edd505
Elephant Butte, NM
Posted: 11/09/19 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I went a different route with direct burial wire and a 30amp outlet. 5W is 50amp so I use an adapter and only 1 A/C.
https://www.amazon.com/Southwire-13055926-100-Foot-Approved-Direct/dp/B000BPCWTG?psc=1&SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-ffnt-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B000BPCWTG
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Shadow Catcher
NW Ohio
Posted: 11/09/19 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Voltage drop at 100' 12 gauge is 4.76V 10 gauge is 3V. Our house voltage is 122V
Cummins12V98
on the road
Posted: 11/10/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Unless you list the gauge of the cord your post is just a nice story. Hopefully the dog survived.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Kevinwa
Western canada
Posted: 11/10/19 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Completely unrelated, but I use 300’ of 12 gauge cord to plug in the block heater on my F350 diesel in the winter. No issues for this as the block heater is a resistive load. We park the truck in a back shed for the winter because it doesn’t get used often.
Cummins12V98
on the road
Posted: 11/10/19 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins Block Heater draws 13A.
Terryallan
Foothills NC
Posted: 11/11/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Honestly don't know the gage. the cord is over 40 years old. Can't remember that far back. But it is pretty heavy, but still flexible. yeah the dog wasn't hurt. it was unplugged when she chewed it off.
