RV.Net Open Roads Forum: Travel Trailers: Replace or reseal skylight
 > Replace or reseal skylight
scarecrow56
palm bay, fl
Posted: 11/10/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
As I said in my earlier post, we bought a used camper. It had a few problems. Nothing major but one is the lap sealant on the skylight has cracked pretty much all the way around and water came in. Question is, better to just reseal the old lap sealant or replace the whole skylight. One is a $20 fix, the other around $150. The 2015 skylight is still in good shape just yellow a bit but no cracks as far as I can tell. Wadda ya think? Thanks
Chillin' in the sun, Palm Bay, Fl.
IB853347201
Eastern Ontario
Posted: 11/10/19 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Remove, clean away old sealant, inspect skylight and if ok, reseal and reinstall...
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
gbopp
The Keystone State
Posted: 11/10/19 07:17am Link  |  Quote  |  Print  |  Notify Moderator
X2. There's no point replacing a good skylight just becsuse it's a little yellow.
GrandpaKip
Flat Rock
Posted: 11/10/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
As above. I had to do the same. I used Eternabond to seal it.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
MFL
Midwest
Posted: 11/10/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Without a picture, showing "cracked all the way around", it is hard to say if all old sealant should be removed. In any case, no sense to replace skylight, unless badly sun damaged (brittle). It takes a lot of product, to reseal a sky light, and towing before sealant cures, can cause roof flex, that may loosen/lift a little, on a new complete reseal. If not badly cracked/opened up, edge of skylight visible, I'd consider a good cleanup on old sealant, just adding new sealant covering cracks.
Jerry
scarecrow56
palm bay, fl
Posted: 11/10/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all, Im gonna just reseal the crack if its not too bad and get on with it! Clean and protect the roof while im at it
RobWNY
Jamestown, NY
Posted: 11/10/19 08:11am Link  |  Quote  |  Print  |  Notify Moderator
You can also try one of the headlight restore kits on the skylight if the yellowing is bothersome.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
colliehauler
Mc Pherson KS USA
Posted: 11/10/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Is it a true skylight or a clear vent? If a vent skylight they are extremely cheaply built. I took my cheap vent out and replaced with a fantastic fan.
The ugly duckling
Central New York
Posted: 11/10/19 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
I also renovated a old 2006 camper. I found that after many years of sun exposure all the plastic parts on the roof became brittle. So, I replaced all the plastic components with new ones. So if it were me and were planning on using the camper for some time, I would replace the sky light with a new one. Really not much more work than repairing and resealing the old one.
Huntindog
Phoenix AZ
Posted: 11/10/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
I am in AZ which gets a lot of sun. My skylight cracked in about 5 years. It was only 20.00 or so for the part.
You are in FL which also gets a lot of sun. You skylight is yellowing, which means the degradation process is well underway. I recommend replacing it, and be be done with it for awhile.
Your money, your choice.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FBP, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
300 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
