scarecrow56
palm bay, fl
As I said in my earlier post, we bought a used camper. It had a few problems. Nothing major but one is the lap sealant on the skylight has cracked pretty much all the way around and water came in. Question is, better to just reseal the old lap sealant or replace the whole skylight. One is a $20 fix, the other around $150. The 2015 skylight is still in good shape just yellow a bit but no cracks as far as I can tell. Wadda ya think? Thanks
Chillin' in the sun, Palm Bay, Fl.
IB853347201
Eastern Ontario
Remove, clean away old sealant, inspect skylight and if ok, reseal and reinstall...
gbopp
The Keystone State
IB853347201 wrote: Remove, clean away old sealant, inspect skylight and if ok, reseal and reinstall...
X2. There's no point replacing a good skylight just becsuse it's a little yellow.
GrandpaKip
Flat Rock
As above. I had to do the same. I used Eternabond to seal it.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
MFL
Midwest
Without a picture, showing "cracked all the way around", it is hard to say if all old sealant should be removed. In any case, no sense to replace skylight, unless badly sun damaged (brittle). It takes a lot of product, to reseal a sky light, and towing before sealant cures, can cause roof flex, that may loosen/lift a little, on a new complete reseal. If not badly cracked/opened up, edge of skylight visible, I'd consider a good cleanup on old sealant, just adding new sealant covering cracks.
Jerry
scarecrow56
palm bay, fl
Thanks all, Im gonna just reseal the crack if its not too bad and get on with it! Clean and protect the roof while im at it
RobWNY
Jamestown, NY
You can also try one of the headlight restore kits on the skylight if the yellowing is bothersome.
If God didn't want us to eat cows, he wouldn't have made them out of Steak and Cheese.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
colliehauler
Mc Pherson KS USA
Is it a true skylight or a clear vent? If a vent skylight they are extremely cheaply built. I took my cheap vent out and replaced with a fantastic fan.
The ugly duckling
Central New York
I also renovated a old 2006 camper. I found that after many years of sun exposure all the plastic parts on the roof became brittle. So, I replaced all the plastic components with new ones. So if it were me and were planning on using the camper for some time, I would replace the sky light with a new one. Really not much more work than repairing and resealing the old one.
Huntindog
Phoenix AZ
I am in AZ which gets a lot of sun. My skylight cracked in about 5 years. It was only 20.00 or so for the part.
You are in FL which also gets a lot of sun. You skylight is yellowing, which means the degradation process is well underway. I recommend replacing it, and be be done with it for awhile.
Your money, your choice.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2011 Silverado CC DA big dually.
