RV.Net Open Roads Forum: Travel Trailers: Screws being pulled out on Awning
 > Screws being pulled out on Awning
scarecrow56
palm bay, fl
Posted: 11/10/19 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
On my Apex 269RBSS there are two vertical channels bolted to the RV. Bolted on top, screws on bottom and 2 screws about midway up. The 2 screws midway are being pulled out of the wall when the awning is fully retracted (all the way in). Also it looks like while doing that it bows the vertical channel out in the middle. As soon as the awning is let out even a little, the channel pops back onto the wall. This is happening on both sides, left and right. Anyone ever see something like this before? Is this a common thing or am I just lucky? Thanks
Chillin' in the sun, Palm Bay, Fl.
ScottG
Bothell Wa.
Posted: 11/10/19 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried just tightening them?
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Huntindog
Phoenix AZ
Posted: 11/10/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Is this a new TT?
It sounds like there may not be a backer board/plate for the screws to bite into. Could be that this was an aftermarket installation, or the factory forgot to install them..... Or maybe the screws just need tightening... Though I am skeptical on this, as none of my awnings have ever loosened up.
I am hoping for you that this is a new TT, under warranty, as a missing backer board is a pretty serious issue.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2011 Silverado CC DA big dually.
Ava
Vancouver Island. BC Canada
Posted: 11/10/19 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Try riveting those areas. I just installed awnings over my windows and they came with screws and rivets for walls with no backing
beemerphile1
Ohio
Posted: 11/10/19 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Something is flexing due to improper installation.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Lynnmor
Red Lion
Posted: 11/10/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Some travel trailers have only a thin piece of sheet metal just under the thin siding for the screws to bite into. I wonder how the screws hold anything. Check to see if the wall is straight using a straight edge like a four foot level, then do the same on the awning mount.
Huntindog
Phoenix AZ
Posted: 11/11/19 02:08am Link  |  Quote  |  Print  |  Notify Moderator
Bad idea. The rivets will pull right thru the thin skin.
Basically, no backer, no awning.
Lynnmor
Red Lion
Posted: 11/11/19 05:37am Link  |  Quote  |  Print  |  Notify Moderator
In the good ole days we had manual awnings that were attached to framing members at the top and bottom. Now we have the wonderful electric awnings flopping around while being attached to a box with the strength of cardboard.
prichardson
Lafayette, La
Posted: 11/11/19 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the mounts are not aligned correctly or the awning material has shifted in the mounting rail. If trailer is new this should be a warranty issue.
GrandpaKip
Flat Rock
Posted: 11/11/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
No, not normal. Something is binding and if not corrected could result in the channel popping off the wall.
Is this a manual or electric awning?
Also, you should be concerned that this is a leak danger.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
