RV.Net Open Roads Forum: Fifth-Wheels: Leave slide out?
 > Leave slide out?
chast
Marlton, NJ
Posted: 11/10/19 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all—just bought a 2010 Bighorn with three slides, that will be parked on a leased lot and lived in for six months of the year in Florida. The question is can it be left parked with the slides out permanently or do I have to bring the slides in when we are not here. There are no slide toppers. What say you??
chartrue2@aol.com
wrgrs50s
Scurry, Tx
Posted: 11/10/19 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Some they do,some they dont,and some they just dont care. That;s probably a short summary of the answers you will get...
Actually, I always leave mine out, but it's because it's parked at my house and I go in and out fairly frequent. If I were leaving it elsewhere, I would leave them in.
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
Dick_B
Palos Heights, IL USA
Posted: 11/10/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Just my $.03 but I say leave them out. I am in the process of replacing the gear motor of my only slide which will probably run around $1K. The more one uses the slide mechanisms the more likely they are to fail.
After reading the other posts am I allowed to change my answer?
Somehow I had in mind that the poster would be moving the slides every week which prompted the original response.
* This post was edited 11/11/19 07:15am by Dick_B *
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
USAFBILL
Alabama
Posted: 11/10/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
If it is going to be in Florida I would pull my slides in..Weather conditions, fires etc may cause it have to be moved in a hurry and if the slides are in then it could be quickly moved..Just my opinion and that would make me sleep better at night.
12th Man Fan
Flower Mound , Texas
Posted: 11/10/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I would pull them in. You need to exercise the motors and bearings ocasionally and you would unnecessarily be exposing the seals ans wipes to UV rays.
Also if the slides are out I feel it is mor vunerable in a storm.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
azdryheat
Tucson, AZ
Posted: 11/10/19 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Look at all the RV's that are lived in full-time.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
scbwr
North Ridgeville, OH
Posted: 11/11/19 04:13am Link  |  Quote  |  Print  |  Notify Moderator
There's no definitive answer so do what makes you comfortable. Personally, I'd put the slides in when not there based on the idea that if bad storms hit, it's less likely to have a problem with any water intrusion.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
pcm1959
home
Posted: 11/11/19 06:01am Link  |  Quote  |  Print  |  Notify Moderator
I live in FL and have my rig at the house and I keep mine in.
While not in use, due to the varying weather conditions as well as the sun/uv damage that occurs in FL, I'd keep the slide closed while away for extended periods.
Keeping them closed will protect all the seals from uv damage. The slide will be less prone to a water leak should one develop when its closed.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
valhalla360
No paticular place.
Posted: 11/11/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
I find lack of use harder on mechanical devices than moderate use.
To the original question: There is no definitive answer. If we are going to be gone for more than a week or two, we usually pull them in.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
wildtoad
Blythewood, SC
Posted: 11/11/19 06:54am Link  |  Quote  |  Print  |  Notify Moderator
You may not have this problem but I normally pull mine in when parked at my house due the flying critters called birds. They like to nest in the space under the slides. Also pull them in for for reasons stated above, less chance of storm related issues. No reason to keep them open.
Tom Wilds
Blythewood, SC
 > Leave slide out?
