RV.Net Open Roads Forum: Class A Motorhomes: 1999 Fleetwood discovery not cranking.
 > 1999 Fleetwood discovery not cranking.
Gordian79
New York
Posted: 11/11/19 12:06am Link  |  Quote  |  Print  |  Notify Moderator
I picked up a 1999 Fleetwood Discovery 36t. When I went to look at the seller connected batteries and it started right up. The next day I pick up the unit and it starts right up.I drove it for about an hour and stopped for some diesel. Once I was done filling it up I went to start it and it didn’t crank over. I could hear clicking sound but it wasn’t turning over. I waited about 15 min are it fired right up. I get it home park it. The next day I start it up no problem.it runs for 15 or so minutes shut it off and same problem not cranking but I hear the clicking. Today I go out to start it again now it won’t crank same clicking. Batteries are charged all battery connections are clean. Water level battery is good. Where should I look first?
joerg68
St. Ingbert, Germany
Posted: 11/11/19 04:50am Link  |  Quote  |  Print  |  Notify Moderator
some ideas:
Possibly the starter solenoid sticking or starter not getting enough power.
Check engine/starter motor to vehicle connections, especially ground connections on vehicle side.
Check battery to vehicle ground connection on vehicle side.
Slightly tap starter motor with a hammer, see if it makes a difference.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 11/11/19 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the contacts in the starter solenoid need cleaning-replaced but first I’d clean-tighten all the connections included the ground. The solenoid can be removed without removing the starter.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
ksg5000
Oregon
Posted: 11/11/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Do the simple stuff first - make sure the battery is good (any auto parts place will test for free) and clean all the contacts and grounds.
Kevin
Gordian79
New York
Posted: 11/11/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
I’m going to check all connections. Old owner had batteries disconnected and every time he was going to use it he would connect them. I don’t like that idea things reset your moving cables around all the time I’m sure there’s something tweak from the constant taking it on and off. I will be adding 2 battery disconnects for engine and house batteries.
RLS7201
Posted: 11/11/19 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Your coach has battery disconnect switches from the factory. They are in the Battery Control Center (BCC). The disconnects are controlled by the two rocker switches by the door, labeled Main & Aux. The BCC is probably in the bay just forward of the batteries.
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job 1946
1941 Hudson
Gordian79
New York
Posted: 11/11/19 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Yes I saw those switches maybe previous owner did not know. I actually have to change one of the rocker switches there the one for the steps.It feels like it’s broken. The old owner said he would disconnect the batteries because something was draining them.ill have to go check fuses with power off to see if something is pulling power.
