RV.Net Open Roads Forum: Onan Generator Fault Code 2- Low oil pressure
 > Onan Generator Fault Code 2- Low oil pressure
Sam Spade
North Central Florida
Posted: 11/12/19 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
timjet wrote:
I changed the oil and filled to the top of the dip stick and that seemed to fix it for about 6 months
Gotta ask.....are you assuming that it is still "full" of oil, or did you actually check it ?
Is it parked on a hill ??
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
maillemaker
office
Posted: 11/12/19 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
While I understand that they might not all be the same......the ones I've seen it is impossible to overfill them to any significant degree. A couple of extra ounces certainly will NOT cause the doom and gloom that you described.
I think I was talking to someone at Onan who told me this advice, and I would have been calling about my Onan 4BGE generator.
But, I can't remember anymore for sure who told me this.
My problem in the end was a bad Hall Effect switch.
Steve
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
timjet
Land O Lakes, FL
Posted: 11/13/19 03:35am Link  |  Quote  |  Print  |  Notify Moderator
The original poster here; I went to the coach yesterday and started the generator, it started up normally. It ran normally and sounded normal for about 15 minutes until I shut it down.
I don't think I have an oil pressure issue, I think it is an electrical issue. I'm going to investigate the electrical control on the unit paying close attention to the connectors.
Tampa Bay
'07 American Tradition Cummins ISL
'14 Honda CRV
Sam Spade
Posted: 11/13/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Fuel pumps seem to be a "high failure" item.
It can fail after 1 minute, one hour or half a day.....or fail to start at all.
And if you share a gas tank, it must be above 1/4 full.
alaska dennis
homer ak
Posted: 11/13/19 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
When is the last time the fuel filter was changed? Not much electrical on diesel. Check voltage on fuel shutoff on injection pump. The next time it shutoffs on you and voltage on electric fuel pump if you have that.
