RV.Net Open Roads Forum: Fifth-Wheels: Propane Tank Gauge,recomendations please
 > Propane Tank Gauge,recomendations please
Page of 5
2oldman
New Mexico
Posted: 11/11/19 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Chuck .. wrote:
Don't want to have to unhook the tanks, pull them out and take them to be refilled if they a near full or run out in the middle of a trip.
Well, if you do that it's easy to tell if they're near full.. assuming you've ever lifted a full one.
Simply unhook the strap and rock them. That way it's easy to tell how much is left.
ford truck guy
Pennsylvania
Posted: 11/11/19 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Roger10378 wrote:
The other one that works quite well is the Mopeka. The only problem that I have had with it is that the battery life is only about a year(or less in cold weather). It uses sonar to check for the height of the liquid/gas interface. I ended up making a remote battery system for mine so that the battery can be changed without removing the propane bottle.
I had this on my system a year or so ago, tossed it out after a few months.... Couldn't get the meter to register the tanks, got new batteries, got new scanners, still nothing
Was too frustrated in messing with that stuff . . .
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
dapperdan
Milwaukee
Posted: 11/11/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Only one is going to go empty at a time.
When Indicator goes from GREEN to RED.....swap indicator lever to other cylinder
Then remove the empty one and go get it refilled.
TWO 30# cylinders (14 gallons) will last a long time
FTng we went 6 weeks on ONE 30#
Pressure inside cyliders doesn't change a lot until almost empty
Overthinking the issue.
We've been using this method for 10 years now, works GREAT for us! One tank valve open, one closed. When tank "A" is empty switch to tank "B" and when it's convienent, get tank "A" refilled. Old Biscuit is spot on!! 30# tank will last a good long time unless you're running the "h" out of your furnace! [emoticon]
Dan
RobWNY
Jamestown, NY
Posted: 11/11/19 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
I use one of these. A full 30 pound tank weighs 55 pounds. Approximately 25 pounds when empty. Whatever it weighs on the scale, tells me how much propane I have left.
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
DutchmenSport
Indiana
Posted: 11/11/19 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Chuck .. wrote:
... These are large/ heavy tanks, back inside a pull out tray on the side of the 5th wheel. ...
What size are these tanks?
I have always run only one tank at a time, even with the automatic cross over system. One tank valve is always closed tight. When the first tank run empty, I switch over to the second tank and close off the first tank. Then, absolute first chance I get, take the empty tank for a fill up and keep repeating. I've never run out of propane doing it this way .... except! This last week-end.
I don't know how I miss calculated, but both tanks were empty. Furnace went out and I've been scratching my head ever since wondering when the first tank ran out and switched over and then did not get the tank refilled immediately. Wife says it was last week-end and due to things going on, we couldn't take in it for an immediate refill. I switched over and another week past. I simply don't remember.
We use our camper every day, and we are going through about 1 thirty pound tank a week right now, running the furnace. During the Summer months, we went 6 months on 1 tank.
time2roll
Posted: 11/11/19 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
I leave both mine on. Don't like running outside in the cold at 2am to flip a valve on.
The red will stay red every single day to continue the reminder to actually fill the cylinder.
675w Solar pictures back up
Veebyes
Posted: 11/11/19 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Bought one of those tape guage thinghys. Waste of money. Since then time & experience has taught me the old fashioned way. How long have we been using it, the knock on the side with the knuckles & a shake without taking it out. The DW uses the colour of the flame as a guide plus the fridge senses low propane.
You know that you are out when things stop working.
2007 Alpenlite 34RLR
toedtoes
California
Posted: 11/11/19 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have ones like Chuck indicated (Astor Propane Tank Pressure Barbeque Gauge).
While it's not exact, it gets me close enough to know the tank is "just about" empty so I can fill it before a trip instead of having to fill it two days into my trip when it's empty.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
fj12ryder
Platte City, MO
Posted: 11/11/19 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I use the scale when checking tanks outside the trailer, I tried the Mopeaka and didn't have the best of luck with it. Not bad, but not very reliable. I use the one like the Dometic or Truma gauge, and it seems to be pretty consistent.
Howard and Peggy
"Don't Panic"
Oasisbob
Portland Oregon 97266
Posted: 11/11/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Open one tank at a time. When tank 1 is empty run off tank 2 while filling tank 1. Key being not to forget filling the empty when you get home.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
Page of 5
