RV.Net Open Roads Forum: Class A Motorhomes: Strange house battery issue
 > Strange house battery issue
pianotuna
Regina, SK, Canada
Posted: 11/21/19 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
wfco is not a great converter. Consider replacement with something better.
Regards, Don
AllegroD
Outdare
Posted: 11/21/19 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
If it were me, I'd get a 12v/120v multimeter. You can get them fairly cheap, almost anywhere. I would disconnect the pos on the batt(s) and run the converter as normal, and measure the output of the converter. Then I would mesure the charge in the batts. I'd post the results here. You will get better and more focused info/diagnosis by posting the test results.
mchero
Henniker, NH
Posted: 11/24/19 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
That converter should be getting 120 volts on the AC side thus charging your batteries. Check for a tripped breaker or blown fuse.
If getting power and charging the batteries you should hear it humming.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
ArchHoagland
Clovis, CA, USA
Posted: 11/24/19 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
What is the voltage at the house battery posts when you measure it?
Have you ever checked the water levels in the batteries?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
AllegroD
Outdare
Posted: 11/24/19 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Octaneforce
Long island
Posted: 12/01/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone. I finally figured out this issue. I was getting funky voltage on the ac side of my converter. There was an old surge protector (like the ones you see under a desk) between where the converter plugs in and the original plug. I removed it, plugged the converter directly into the outlet, and my problem was solved!! Thanks for the help. I went ahead and installed a “smart” power inverter that was suggested anyway. Pd9260c.
1993 fleetwood coronado 30’ class a chuggin along with a tbi 454
An On demand hot water heater was the best thing i ever did
time2roll
Posted: 12/01/19 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Your battery will perform far better and last far longer with the 9260.
675w Solar pictures back up
John&Joey
Summer-North,Winter-South
Posted: 12/01/19 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Check the water level.
Jennifer Koper
494 Norman Street
Posted: 12/01/19 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Used batteries cost about $500 a kilowatt-hour to change to stationary storage systems, about half the cost of batteries fresh off the factory floor. That will provide an opening for solar installers to cheaply add storage space to rooftop systems until new battery expenses come down.
toolttime
Morinville Ab Canada
Posted: 12/03/19 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Check the ground connection at investor and battery
2015 Thor Tuscany 45AT
