RV.Net Open Roads Forum: Class A Motorhomes: battery charging
Tom/Barb
Oak Harbor, Wa
Posted: 11/11/19 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
how long should we stay on Float charging before change. ??
We are now about 3 months of no change.
13.3 Volts steady
Should I disconnect for a while, and allow the batteries to disconnect for a while.
Ed_Gee
Central Oregon coast
Posted: 11/11/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Float charge at that voltage should be fine......but if a wet cell just check the water level occasionally.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
ScottG
Bothell Wa.
Posted: 11/11/19 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
13.2~13.3 is good forever. You can forget about it!
I will check my water levels in the spring and very little, if any, will be needed.
S
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
time2roll
Posted: 11/11/19 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
Will not hurt to run overnight on battery power once every 30 to 90 days.
IMO a few cycles now and then is fine and proves what is working.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 11/11/19 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
There is some evidence that cycling helps batteries last longer. I'd suggest that one day per week you run from the battery bank.
Regards, Don
Sam Spade
North Central Florida
Posted: 11/12/19 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Some "tenders" turn off and on but most just drop down to the float level, which is what yours has done, and stay there more or less forever.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
