RV.Net Open Roads Forum: Tech Issues: Microwaves on inverters.
 > Microwaves on inverters.
phemens
Montreal, Canada
Posted: 11/12/19 07:18am Link  |  Quote  |  Print  |  Notify Moderator
I just recently bought 5 x 100AH LIFePO4 batteries from a Canadian manufacturer (I researched first, and spoke with him at length, he's an electrical engineer by trade). Each battery was $750 CAD. So far so good, they are good quality and easily power my Samlex 3000w inverter. Sure, they are more expensive than FLA, but weight and voltage drop were the primary concerns for me. Not sure it would be assumed that this would be in addition to house batteries or that a separate bank is required...
If the OP wants the contact info, PM me.
Bobbo wrote:
KJINTF wrote:
Close to my setup - YES it can easily be done - Ours Works Great
1200 watt inverter microwave used many times during the day but no coffee pot Just yet
Our 2Kw sine wave inverter easily powers the microwave for as long as needed
The other half of the equation the batteries, charging & Metering / monitoring
200amp/hr LiFe battery bank that is dedicated to the inverter and heater blower motor no other house loads. A 220amp/hr lead acid battery bank for house loads. 600watts of solar and when cloudy for extended periods a 4kw generator with both a 100amp and 75amp converters
Build yourself a nice system and you will enjoy it for years to come
Any estimate on what a 200amp/hr LiFe battery bank would cost? (Remember, this is IN ADDITION to the house batteries.)
Here is a link to a 100amp/hr LiFe battery for $1,300.00. Two of them would be over $2,500.00. I assume that is ball park.
LiFe 100amp/hr battery
Do you REALLY want microwave/Mr. Coffee THAT badly?
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
CA Traveler
The Western States
Posted: 11/12/19 07:50am Link  |  Quote  |  Print  |  Notify Moderator
4x GCs will be adequate. MW and coffee pot are usually limited time use. For example the MW could draw 150A for 10 minutes. That's less that 30Ah that needs to be replaced.
No issue with my large MW and 2000W inverter. No idea why others are concerned about MW surge which would be a concern with motor appliances.
2014 Grand Cherokee Overland
Bob
BFL13
Victoria, BC
Posted: 11/12/19 07:58am Link  |  Quote  |  Print  |  Notify Moderator
doughere wrote:
I have a unit with 1500 watt microwave and would like to be able to use it occasionally when dry camping (10 min or less at a time). I plan to use a 2000 watt pure sine wave inverter. Also plan using it on a 900 watt coffee maker (about 15 min a pot). Anyone have any experience with this setup?
Thanks,
Doug
Yes it works, been doing that with MW, kettle, and toaster for the last ten years--BUT:
- A "1000w" MW requires way more than that for input (see the label on the back for input required) might be 1500w.
So--what do you mean by "1500w"??? If that is the cooking size of the MW then it will want more than the "2000w" inverter can do (which also will have lower than that wattage as its "continuous" rating.)
You go by the "divide by 10" rule for your DC amps draw with the inverter. 1500w would be 150 amps draw, and 1200w would be 120a, etc. The 900w coffee maker would be 90 amps draw.
Now you look at the draw from a MW when using PSW or when using MSW inverters. First the MSW inverter needs to be a robust type that can run motors with starting surges. They exist, so assume you have one.
Also assume your MW is less than 20 years old so it will run on MSW. Some older MWs will not run at all on MSW. If it does run on MSW, it will run at less power and take a little longer to do the job than a PSW that will run the MW at its full power. If it can barely run, it will groan and moan, so make sure the MSW power is well over what the MW needs as a minimum so it runs ok but just "slower".
What that all leads up to is that the same "1000w" MW will pull 150 amps with PSW, but only about 120a with MSW. (It works out that the longer time with 120a is still fewer AH than the shorter time at 150a, but that AH diff does not matter much in the big picture of your whole daily AH use)
Note that the coffee maker will be the same 90 amps on MSW as on PSW because it is not motor driven.
-Now the coffee maker. 90a for 15 minutes can be an issue. I used a 90a kettle for a single cup at a time taking 3 minutes to boil. Three cups in succession over about an hour and a half in the morning. Never a problem until I got AGMs. After a year of maybe 36 times doing the three cups thing (using three days a month), the AGMs have started acting up.
It turns out they might have warped plates or something that get back to normal at lower draws of say 30 amps, but now they don't like the high amps draws for very long. I can do a single high amps draw no problem, even a second, but a third one and the AGMs collapse. The inverter low-voltage shut down happens. So I don't do the three cups with the kettle anymore, I do the coffee water on the stove. I still use the MW And toaster as one time shots, no problem
So the coffee maker at 15 minutes is one shot, but is a long time. I don't know how AGMs would like that. I was always able to use the MW for say 10 minutes and then right away for another 5 minutes when I had Wet batteries. Say DW inside does two spuds for 10, then frozen veg for 5 with me doing steak outside on the RVQ, onion/mushroom garnish on stovetop.
(Drat--now I want to go camping!)
So yes, you can do it ok if you really have a 1000w MW, not a 1500w one, and you have about 400AH of batteries for the 2000w inverter, and if those batts are Wet, not AGM. You might be able to do it with AGMs a few times and get away with it.
It might be that there was something wrong with my particular AGMs that made that happen, and it would not happen with anybody else's.
Don't know about Li batts. ( If you can afford Li, why are you in an RV instead of at the Sheraton? [emoticon] )
* This post was edited 11/12/19 08:15am by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
vermilye
Oswego, NY, USA
Posted: 11/12/19 08:45am Link  |  Quote  |  Print  |  Notify Moderator
I used a 700 watt microwave & a 5 cup 600 watt drip coffee maker with a 1500 watt PSW inverter on a pair of 232 amp hour 6V golf cart batteries, recharging with between 360 & 420 watts of solar. There were days that because of clouds, rain, etc that I skipped the microwave use, but almost always made the pot of coffee. Used 6-8 amp hours for the coffee. As long as you monitor the batteries & have a means to recharge them, it will probably work. Some microwaves are pretty inefficient, which could present a problem.
That said, when the microwave died, I replaced it with a 950 watt Panasonic inverter microwave. The advantage of the inverter type microwave is when you dial down the power it actually drops the input wattage. At lower power levels, a standard microwave runs off & on at full power. When the batteries are low, I can dial down the microwave to as little as 300 watts. It also does a much nicer job of defrosting - no cooked edges of food.
Jon Vermilye My Travel Blog
My Photo & RV link blog
naturist
Lynchburg, VA
Posted: 11/12/19 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Battleborn batteries
Relion batteries
time2roll
Posted: 11/12/19 09:59am Link  |  Quote  |  Print  |  Notify Moderator
4x GC2 and 400 watts solar to go with that inverter will work fine.
Lithium is great but not necessary. If you go lithium make sure the parallel capacity is 200+ amps.
675w Solar pictures back up
ktmrfs
Portland, Oregon
Posted: 11/12/19 11:58am Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Doug
run our microwave quite often on an inverter. you will need enough battery and big short cables from battery to inverter.
Now one thing to consider, which we did was to toss the original microwave in the donate pile and buy a panasonic true inverter microwave. It's operation is much different than traditional microwaves. when in partial power mode it doesn't cycle between 0% and 100%, it actually runs at the % set. So.... if you set it to 50% that's what it runs at continually. Ours is a 1500watt microwave and I run it easily on a 1000W inverter if power is set to 50% or less. At 50% power it does NOT take twice as long to heat something, more like 25% longer.
I also have a hotel type keurig that draws 900W and we run it off the 1000W inverter with no problems either.
for this type of draw I'd recomend either 4 GC2s or a bank of 12V. GC2's aren't great for large current draw and have high internal resistance compared to a 12V jar. So with only 2 GC2's your inverter may shut down when batteries are below 75%ish SOC. With 4 GC2's it should work down to 50%. I run 4GC2's, with only 2 it only worked with batteries charged above 75% or so. A few others have had similar experiences.
2011 Keystone Outback 295RE
steved28
Bellingham,MA,USA
Posted: 11/12/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Our Winnebago has this setup as a stock configuration. 2KW inverter and household microwave (not sure of the wattage). It works fine. We also use a K-Cup machine in the AM. BUT, I have 800Ah of batteries (I'm sure you could do with half that). Another tip I used to perform when my setup was less than this, heat hot water on your propane stove and pour it into the k-cup (or standard coffee maker). It takes a lot of juice to heat that water. If pre-heated, the unit only runs a pump.
2019 Winnebago Sunstar LX 35F
2000 Jeep Wrangler TJ Sahara
time2roll
Posted: 11/12/19 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
Shot-N-Az wrote:
I suck at math, and I’m no electrician, but real world experience is that I can microwave on my inverter but it takes a lot longer than normal.
Is that a sine wave inverter?
Very common for a MSW to cook slower as the peak wave voltage underdrives the megatron.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 11/12/19 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
I have four Trojan T125 batteries and a 2000W inverter and often use our 1200W microwave to warm food for lunch or a cup of hot water, usually for no linger than four minutes at a time with no problems.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
