RV.Net Open Roads Forum: Class A Motorhomes: Class A Fulltimer freeze concerns
 > Class A Fulltimer freeze concerns
HighwayJunky
Kissimmee
Posted: 11/12/19 06:31am Link  |  Quote  |  Print  |  Notify Moderator
So, I have a Late model Class A which we plan to use as our home. With winter coming I plan to prevent frozen pipes by using our furnace to heat the unit. I understand that with insulated bays I need not worry about freezing. I do not plan on being in a freeze zone for any long periods of time but accidents do happen.
Do I need to be concerned about our unit and plan?
2017 Newmar Ventana LE Diesel Pusher
2012 Fiat Pop Toad
One wife
No pets
No complaints
No Worries (except keeping wife happy!!)
Fulltime jobhttps://www.rv.net/SharedContent/cfb/images/rolleyes.gif
Ed C
Cape Cod, MA
Posted: 11/12/19 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Newmars are well insulated; as long as you use your furnace you should have no problems.
Ed/Jeanie & Slade the GSD
2017 Entegra Aspire 42 RBQ/ Sierra Crew
Flute Man
Payson, Arizona
Posted: 11/12/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
I never have had frozen water lines. If I am in a freezing area for any great period I put a heat tape on the waterline from the spigot up to the motorhome.You may call me if you have any questions. Be happy to share with you.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
Two Jayhawks
Lenexa Kansas
Posted: 11/12/19 07:20am Link  |  Quote  |  Print  |  Notify Moderator
It's good to keep a watchful eye on low temps. I'll also reiterate that Newmar's are so well insulated it shouldn't be an issue. For your own piece of mind why not get a wireless thermometer, place in basement, & you can see for yourself how warm it is staying.
Bill & Kelli
2015 DSDP 4366 pulling a 2014 Ford Edge
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
DrewE
Vermont
Posted: 11/12/19 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Within the motorhome, there shouldn't be problems, as others have said.
You do need to disconnect the water supply hose in freezing weather lest the water spigot and the water inlet freeze and split. (Most hoses are flexible enough to withstand freezing water in the hose proper, but brass and plastic fittings have rather less give.) There are heated hoses etc. to work around this, but I don't think they'd be worth it for you when you won't be spending a good deal of time in freezing conditions.
It wouldn't hurt to stow the sewer hose as well in freezing conditions.
kdk
usa
Posted: 11/12/19 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
If really want to be safe, go to tractor supply and buy a freeze cube. They plug in a electrical socket and at 35 degrees they will turn on a heater and off at and 45 degrees. Used for animal water tanks. Go to walmart and purchase a 400 watt personal heater. Put this in your wet bay and worries are over.
06 Holiday Rambler Ambassador
2015 Wrangler Sahara 4 door
Bill.Satellite
Full-timer
Posted: 11/12/19 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
At night you might not run the furnace enough to keep the bays warm. Getting a remote thermometer is great advice and you can adjust you bay heat as necessary. A couple of light bulbs, small personal heater(s), heat mats, freeze cubes can all be added as necessary to keep everything underneath warm. Much depends upon "how cold and how long". We long term in very cold weather at times without issue but it does take some interaction on your part.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
time2roll
Posted: 11/12/19 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
How cold is cold? While in use most any RV is good to about 25. If yours is well made as said above you are probably fine to at least 20 and maybe lower.
675w Solar pictures back up
AllegroD
Outdare
Posted: 11/12/19 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
We use a 200w heater with large electric extension cable, from entertainment bay and a TC-3 Cold Weather Thermo Cube Thermostatically Controlled Outlet (in the wet bay).
pianotuna
Regina, SK, Canada
Posted: 11/12/19 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
Don't forget to protect the fridge. See the thread in full time called winter camping.
I use a thermocube on my fridge with a 60 watt light bulb. I also restrict the air flow by blocking some of the vents.
I use a 600 watt heater on a mechanical thermostat to keep the waste tanks unfrozen.
Replace the return air grill with twin window fans. I use a 2nd mechanical thermostat to operate the fans. They pressurize the duct work and keep the water lines from freezing up.
Regards, Don
