RV.Net Open Roads Forum: Travel Trailers: Insulating exposed tanks
 > Insulating exposed tanks
Twistedlarch
Cottage Grove, OR.
Posted: 11/12/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Hey all, I've done a search on this topic and returned no hits. So here it goes:
My kids are part of our local ski area's ski team, I would like to start taking my trailer up on the weekends instead of driving the 2 hour trip (one way) every Saturday & Sunday. The ski area has Power hookups but no water.
The average night time temps at the ski area hover in the teens and sometimes lower, average day time temps seem to hover in the mid 20's
My trailer has fully exposed tanks...33 gal.Fresh, 25 gal grey, and 25 gal black. I have purchased tank heaters for all three.
My plan is to apply the tank heaters then wrap the tanks in Reflectix, then enclose the tanks with R-5 foam board then seal with another layer of Reflectix. Overkill? Not enough?
Thanks
Brian
bid_time
Michigan
Posted: 11/12/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
I think your wasting your time and money. Use the beds, stove, tv, etc and forget about trying to use the water and related systems. Just my opinion. Camped many a nights in a TT while hunting in winter. Only water I needed was carried in a 5 gal bucket, and disposed of outside.
MFL
Midwest
Posted: 11/12/19 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
IMO, not overkill. A trailer not designed for cold temps can use all the help it can get. Reflectix is a good product for holding heat in, and cold out. Foam board is good too, due to being somewhat waterproof. There is a quality difference between brands. I like Owens for my uses.
Hope moisture does not become a problem, but with hookups, you could run a dehumidifier.
Jerry
ksbowman
Kansas
Posted: 11/12/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
After the heating pads are installed have you considered have the tanks sprayed with insulation? The spray insulation is also great on sealing any openings.
garym114
Bluff Dale, Texas
Posted: 11/12/19 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the trailer is not all weather. This means all your water piping and water manifold is also exposed.
An all weather RV has the piping and tanks enclosed with a heater duct directing heated air to the enclosure.
Take a look to see.
Twistedlarch
Cottage Grove, OR.
Posted: 11/12/19 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Take a look to see.
The water pump is inside and there is only one exposed water pipe that travels across the bottom of the trailer for about 6 ft then disappears back inside. I figured I can use heat tape then enclose in pipe insulation.
beemerphile1
Ohio
Posted: 11/12/19 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Reflectix is the wrong product. If you read the manufacturers documentation it's best at reflecting, not insulating. It is only R-1
I would consider either dry camping or buy a more suitable RV.
If you must use what you have, build a box from foam board to encase the tanks.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
TurnThePage
North ID
Posted: 11/12/19 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
I did the heater pads, then insulated with foam board and expanding foam at the corners, then hung coroplast between the frame rails surrounding the whole thing. I also added a heat pad to the area where the black/grey tank drains merge, then wrapped it too. Probably overkill. I've never needed to use that last feature.
2015 Ram 1500
2004 Pioneer 18T6
time2roll
Posted: 11/12/19 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
I have fully exposed tanks. I added UltraHeat brand tank heaters. (120v) Been fine down below zero. I have no added insulation. Might be over thinking it for just a weekend. Don't forget the drain pipes and valves. Worst case you will need to dump after it thaws a bit after you get off the hill.
675w Solar pictures back up
Huntindog
Phoenix AZ
Posted: 11/13/19 01:37am Link  |  Quote  |  Print  |  Notify Moderator
My second TT was similar to yours. It could sustain some pretty cold temps IF, I ran the furnace nonstop. Even though it did not have an enclosed underbelly, the heat ductd ran right across the tops of the tanks under the floor. Enough heat radiated into them to make it work. I did have frozen dump valves from time to time.
I did not have hookups either. Just ran a Honda EU2000.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
