RV.Net Open Roads Forum: Wanna bring a golf cart and a Jeep towed
 > Wanna bring a golf cart and a Jeep towed
Page of 5
RJL
Manahawkin, New Jersey
Posted: 11/13/19 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Spot on summary . . . which has unfortunately been pretty much ignored. I'm guessing OP has disappeared for good.
Don't know why you'd think I've "disappeared for good". I just posted this last night.
2010 Damon Challenger 368, F-53 Chasis
2010 Jeep Wrangler Rubicon unlimited, Toad
1996 Ford F250 XLT 4x4-work in progress
2019 Dodge Challenger Scat Pack Wide Body.
Dale.Traveling
Newport News, VA
Posted: 11/14/19 03:22am Link  |  Quote  |  Print  |  Notify Moderator
RJL wrote:
Well Thank you all for the spot on advise. @Dale.Traveling thanks for the heads up. The cricket mini golf cart has me intrigued. That may be deal moving forward.
Thanks again.
Bob
Seen pics of a Cricket folded up and in the back of a Honda CR-V. Not sure how you could bring it along and tow the Wrangler. Maybe the swivel wheel platform on the Wrangle. At 300 lbs shouldn't be a problem. Cricket
2006 Hurricane 31D built on a 2006 Ford F53
stvdman
MD
Posted: 11/14/19 04:14am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, didn't take into account the towing limit of that chassis. We have a 2017 F-53 with the larger chassis, recently bought a Gladiator and plan on filling the bed up with toys to drag along.
dodge guy
Bartlett IL
Posted: 11/14/19 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Some MH's on gen F53 chassis have a very high CCC. Mine is 4k lbs. i on,y use about 2k of that. If you replace the hitch with a higher rated version and stay under your Ratings you could safely bring a golf cart and a car. You just have to do your homework on the ratings.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
tropical36
Southwest Florida_USA
Posted: 11/15/19 09:11am Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
The gladiator bed isn't big enough for a golf cart. Golf carts are 8ft long the gladiator bed even with the tailgate down is around 6ft.
Hmmmmmm, here I was hoping that the Jeep was as long as an F150 super crew, since I've hauled them in ours. The bed on the Ford is around 5ft with the gate closed and with it open the back wheels sit on it, just about right. Maybe a sheet of 3/4 plywood, would make up the difference.
So you're saying that you've actually tried putting a golf cart in the bed of a Gladiator?
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Alan_Hepburn
San Jose, Ca, USA
Posted: 11/15/19 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Just for fun I googled "Jeep Gladiator Dimensions" and here's what popped up:
"By the numbers, here's how the Gladiator's bed size measures: The bed floor is 60.3 inches long with the gate closed, the bed width at the tailgate is 56.8 inches, and the gate opening itself is 50 inches wide while the floor between the wheel humps is 44.8 inches wide."
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
dodge guy
Bartlett IL
Posted: 11/15/19 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, not something else would want to put a golf cart into. Not too mention that the rear axle is located very far forward. So the golf cart will make it very heavy on the rear axle. Not to mention probably being over the less than 1k lb CCC. I work at a Chrysler Dodge Jeep Ram dealer and see them quite often. Not much you can do with the bed other than haul some flowers.
Ken C
Rapid City, SD, formerly SF Bay Area, Ca
Posted: 11/26/19 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
rk911 wrote:
RJL wrote:
We're selling our vacation home in SW Fla and plan on using our Challenger for future vacations of a month to 6 weeks. I'm thinking I might want to buy a golf cart to bring along with my Jeep towed. Is there a way to do this? Maybe something to put the golf cart on and then hook up the Jeep.
double towing is illegal in some states. an enclosed double deck trailer comes to mind but is likely too heavy for the MH chassis to safely tow. may i suggest that before you embark on this plan that you know and thoroughly understand your Damon's various weight ratings (GCWR, GVWR, GAWR as well as the actual rolling weight of your loaded MH and the items you want to tow. your rubicon likely weighs over 4K pounds by itself.
be safe.
Trade your Jeep in for the new Jeep pickup and haul your golf cart in the bed of the Jeep. Likely cheaper than a stacker trailer a a whole lot less weight to haul.
Ken
2018 Newmar Dutchstar
Spartan K2
2015 Jeep Cherokee Trailhawk
mdanielson55
tyler texas
Posted: 11/27/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
ihave a cricket golf cart and it is smaller than a regular cart it will fit in all truck beds and and will fit in most suvs it fits in on of my bays the 4 door jeeps it will fit in
hohenwald48
Nashville, TN
Posted: 11/27/19 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Lot of folks with a lot of ideas that ignore weight and towing capacity. My 2017 Wrangler JKU weighs 4940 on the CAT scale. I imagine a Rubicon is probably more. On just about every gas motorhome, once you hook up a 4940 pound Jeep you're out of tow capacity and there's no way to haul more.
When seconds count, the police are only minutes away.
2015 Open Range 216 RBS
2013 Nissan Armada Platinum
Page of 5
