RV.Net Open Roads Forum: Travel Trailers: Plumbing HELP..?
 > Plumbing HELP..?
VickieB68
United States
Posted: 11/13/19 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Bought a 1995 Skyline Boomer, M2010. It has to be replumbed as all the lines leaked antifreeze when I attempted winterizing. I can not locate any information on this camper.
Does anyone know if the water lines from the front fresh water tank to the rear water heater run underneath the wetbath or along the wall behind the wetbath? I am wondering if I pull out the wetbath back wall whether I can get to those lines and find leaks.
pianotuna
Regina, SK, Canada
Posted: 11/13/19 08:10am Link  |  Quote  |  Print  |  Notify Moderator
VickeB66,
Simply run new lines made from Pex. Then there will be no leaks--and you can route the lines inside the heated area of the RV.
The lines can be "fished" past obstructions.
Regards, Don
VickieB68
United States
Posted: 11/13/19 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Pianotuna: Thank you. All the water lines are inside the camper. So, do I run new lines and just ignore the old ones and leave them in place? If room, I see no problem doing that.
midnightsadie
ohio
Posted: 11/13/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
yes . you,ll find pex lines easy to work with.
VickieB68
United States
Posted: 11/13/19 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Thank you. I have already checked into Pex & that seems the best choice. The sharkbite fitting are very expensive so I'm debating those.
opnspaces
San Diego Ca
Posted: 11/13/19 08:37am Link  |  Quote  |  Print  |  Notify Moderator
For a complete replumb I would go with buying the crimper and crimp sleeves over sharkbites.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
pianotuna
Regina, SK, Canada
Posted: 11/13/19 08:44am Link  |  Quote  |  Print  |  Notify Moderator
I'd ignore the oem lines and leave them alone. Rent a crimping tool--or buy one.
gbopp
The Keystone State
Posted: 11/13/19 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, they are not cheap. But, they work great and are easy to use. Figure out how many you will need for your project and compare it to buying or renting a Pex crimper.
Then, look at where you will be making the connections. Using a crimper on a workbench and using it while reaching into a tight space while standing on your head are two different animals.
I've had SharkBite fittings on my home heating and plumbing systems for about 12 years. I've never had a leak or failure.
OleManOleCan
Alabama
Posted: 11/15/19 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
VickeB66,
When I rebuilt my 1975 Fleetwood Prowler, I put in Pex.
Works great.
Now all my lines are inside...
time2roll
Posted: 11/16/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Unless the old line is handy to pull the new PEX into place.
675w Solar pictures back up
 > Plumbing HELP..?
